- Release Notes
- Getting Started
- Setup and Configuration
- Automation Projects
- Dependencies
- Types of Workflows
- File Comparison
- Automation Best Practices
- Source Control Integration
- Debugging
- The Diagnostic Tool
- Workflow Analyzer
- About Workflow Analyzer
- ST-DBP-023 - Empty Workflow
- Variables
- Arguments
- Imported Namespaces
- Control Flow
- Object Repository
- Logging
- The ScaleCoordinates Migration Tool
- StudioPro
- Extensions
- Troubleshooting
Studio User Guide
If you encounter any issues, please consult the troubleshooting guide.
The steps for installing the extension for Edge Legacy and Edge Chromium are the same. The setup procedure automatically detects the type of browser installed on your machine and deploys the corresponding extension.
- Access the Tools page from the Studio Backstage View. The extensions you can install become visible.
- Click the Edge button. A confirmation dialog box is displayed. The extension is now installed.
- Click the Windows Start button and type
cmdin the search field. - Right click on Command Prompt and run it as administrator.
- Change the directory to the UiPath installation folder (cd C:\Program Files (x86)\UiPath\Studio\UiPath).
- Use the
SetupExtensions.exe /Edgecommand to install the extension. A confirmation pop-up is displayed in Edge. -
Start (or restart) the Edge browser, so the installation can complete. A new UiPath icon appears in the top right:
If the computer is not part of a domain, the setup opens the Microsoft Store page to download and install the extension. In this case, simply follow these steps:
- Click the Get button once the Microsoft Store is opened.
- Wait for the Edge extension to install, then click the Launch button. The Edge browser is opened and a pop-up is displayed.
Click the Turn it on button to activate the UiPath Extension for Edge. The extension is now installed and a new UiPath icon appears in the top right.
