- Getting started
- Understanding UiPath Robot
- Installation requirements
- Installing robots for unattended automations
- Configuring robots for unattended automations
- Deploying unattended automations
- Connecting robots for unattended automations to Orchestrator
- Setting up Windows Server for High-Density Robots
- Redirecting robots through a proxy server
- Implementing authentication with credential providers
- Configuring package signature verification
- Setting up package folders and network paths
- Configuring activity feeds
- Using EntraID users with multifactor authentication (MFA) for unattended robots
- Installing robots for attended automations
- Configuring robots for attended automations
- Integrations
- Governance
- Troubleshooting
Solutions for Robot-to-Orchestrator connection errors, including authentication issues and interactive sign-in configuration problems.
Interactive sign-in is not enabled for this tenant
The tenant you are trying to access does not have authentication enabled.
Potential issue
The tenant might have been created in an older version of Orchestrator, prior to the implementation of the interactive sign-in feature.
Solution
The proposed solution must be performed by an Orchestrator administrator:
- In Orchestrator, go to Tenant > Settings > Security , and then select Allow both user authentication and robot key authentication.
To connect using your machine key instead, go to the sign-in screen in Studio, then select More Options > Connect to Orchestrator.
Interactive connect is not available
You cannot connect through the Interactive Sign-In.
Potential issue
The Robot is installed in Service Mode.
Solution
When the Robot is installed in Service Mode, connect using the Machine Key first, then proceed with Interactive Sign-In (Service URL).
Robot does not exist
You receive the error message "Robot does not exist".
Potential issue
You might be using a classic robot, which was defined in Orchestrator using the classic method or via the Windows user, and you are already connected to Orchestrator with a machine key. When you then sign in from Studio, a different username is sent to Orchestrator.
Solution
- In Orchestrator, set up a modern robot, then sign in again.
Cannot acquire a license
You receive the error message "Cannot acquire a license".
Potential issue
Your user account is not properly configured to acquire a license from Orchestrator.
Solution
- In Orchestrator, edit the problematic user account to execute attended automations, then assign it an Attended license.
To verify the license availability, go to Tenant > License.
No such host in known
You receive the error message "No such host in known".
Potential issue
Connection to Orchestrator could not be established.
Solution
Verify that your Internet connection is working.
You are not authorized to perform this action
You receive the error message "You are not authorized to perform this action".
Potential issue
The user connected with the machine key associated with one tenant, but then tries to sign in to a different tenant.
Solution
For User Mode installations, sign in using the service URL.
For Service Mode installation, sign out from the Assistant, then sign in again.
Could not start executor in an RDP setup
You receive the error message "Could not start executor. RDP connection failed: Message: The connection transport layer failed. Last error: 131085".
Potential issue
The user account used to run the unattended automation runs was not added to the Remote Desktop Users group.
Solution
Add the user account to the Remote Desktop Users group. For details, see User permissions to run automations.
Robot cannot connect to an Automation Suite Orchestrator instance
When trying to connect or sign in to an Orchestrator provided with Automation Suite 2024.10, you may encounter this error: "System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception."
This issue affects Windows 10 and Mac operating systems.
Potential issue
Automation Suite 2024.10, which hosts the Orchestrator instance you want to connect to, uses TLS 1.3 by default. Windows 10 and Mac operating systems do not support this version.
Solution
You have two options:
- Configure Automation Suite 2024.10 to use TLS 1.2 instead, or
- Use an operating system other than Windows 10 or Mac.
- Interactive sign-in is not enabled for this tenant
- Description
- Potential issue
- Solution
- Interactive connect is not available
- Description
- Potential issue
- Solution
- Robot does not exist
- Description
- Potential issue
- Solution
- Cannot acquire a license
- Description
- Potential issue
- Solution
- No such host in known
- Description
- Potential issue
- Solution
- You are not authorized to perform this action
- Description
- Potential issue
- Solution
- Could not start executor in an RDP setup
- Description
- Potential issue
- Solution
- Robot cannot connect to an Automation Suite Orchestrator instance
- Description
- Potential issue
- Solution
