automation-cloud-public-sector
- Getting started
- Data security and compliance
- Organizations
- Authentication and security
- Understanding authentication models
- Configuring the Microsoft Entra ID integration
- Setting up SAML SSO with Microsoft Entra ID
- Setting up Okta as your identity provider
- Setting up PingOne as your identity provider
- Managing UiPath signing certificate for SAML authentication requests
- Local users password complexity requirements
- Licensing
- Tenants and services
- Accounts and roles
- External applications
- Testing in your organization
- AI Trust Layer
- Notifications
- Logging
- Troubleshooting
Automation Cloud Public Sector admin guide
Last updated Nov 11, 2025
Note: The instructions in this section are for a sample configuration. For more information about any IdP settings that are not
covered, refer to PingOne.
- In a different browser tab, log in to the Ping One Admin Console.
- Go to Connections > Applications, and select the plus icon .
- Select Web App, and for SAML select Configure.
- On the Create App Profile page, specify a name for your Automation Cloud app.
On the Configure SAML Connection page, select Manually Enter and provide the following details:
- ACS URLs: Enter the Assertion Consumer Service URL value you got from Automation Cloud.
- Entity ID: Enter the Entity ID value you got from Automation Cloud.
- SLO binding:HTTP Redirect
- Assertion Validity Duration: Enter the number of seconds for the validity period.
- Select Save and Continue.
- On the Map Attributes page, add the email address:
- Select + Add Attribute.
- For Application Attribute, enter
http://schemas.xmlsoap.org/ws/2005/05/identity/claims/emailaddress. Thehttp://schemas.xmlsoap.org/ws/2005/05/identity/claims/emailaddressclaim is case-sensitive. - Set Outgoing Value to Email Address, or the user attribute that contains the user's unique email address.
- Select the Required checkbox.
- Optionally add other attribute mappings. Automation Cloud also supports the First Name, Last Name, Job Title, and Department user attributes. The attributes are case sensitive. This information is then propagated to Automation Cloud, where it can be made available to other services, such as Automation Hub.
- Select Save and Close.
- Turn on the toggle for the Automation Cloud app to enable the application for user access.
- On the Configuration tab, copy and save the IdP Metadata URL value for later use.
