- Getting Started
- Setup and Configuration
- Automation Projects
- Dependencies
- Types of Workflows
- Control Flow
- File Comparison
- Automation Best Practices
- Source Control Integration
- Debugging
- Logging
- The Diagnostic Tool
- Workflow Analyzer
- About Workflow Analyzer
- ST-DBP-023 - Empty Workflow
- ST-USG-005 - Hardcoded Activity Properties
- ST-USG-032 - Required Tags
- Variables
- Arguments
- Imported Namespaces
- Coded automations
- Introduction
- Registering custom services
- Before and After contexts
- Generating code
- Troubleshooting
- Object Repository
- Extensions
- About extensions
- SetupExtensions tool
- Screen resolution settings
- Group Policies
- Multiple browser profiles
- Group Policy conflict
- Chrome Extension on Mac
- Group Policies
- List of extensions for Edge
- Extension for Safari
- SAP Solution Manager plugin
- Excel Add-in
- Studio testing
- Troubleshooting
- About troubleshooting
- Assembly compilation errors
- Microsoft Office issues
Control Flow in Studio: the order in which actions execute in an automation and how to manage it using sequences, flowcharts, and loops.
An important aspect of successfully working with Studio is understanding and knowing how to control your project. Control Flow is a concept borrowed from computer science that refers to the order in which actions are performed in an automation.
A proper Control Flow can be achieved through the intelligent use of variables and activities.
All of these activities can be found in the Activities panel, under Workflow > Control.
These activities enable you to define rules and automate conditional statements within the project, through if/else and for each statements or loops.Delay can also be added between actions, in order to perfectly time activities.
Loops represent an important part of automations as they enable you to easily check dependencies between variables, activities and conditions. Once created, they enable the user to run a segment of the automation for a specific number of times, until a condition is met, or indefinitely.
