robot
Robot developer guide
  • Robot JavaScript SDK
    • About the Robot JavaScript SDK
    • Configuration Steps
      • Settings fields
Settings fields
The Settings property of the Robot JavaScript SDK allows you to personalize and improve your control over the setup of the browser add-on.
class Settings {
  portNumber: number;
  pollTimeInterval: number;
  disableTelemetry: boolean;
  appOrigin: string;
class Settings {
  portNumber: number;
  appOrigin: string;
AttributeDescription
portNumberAllows you to configure custom ports on which the back-end services run on. The default port number is 2323. Please note that this is only available for Enterprise installations.
pollTimeIntervalAllows you to specify the time in milliseconds in which the Robot JavaScript SDK keeps track of a process execution from a web page. The default value is 250 milliseconds. This value determines the polling frequency from the web browser
disableTelemetryAllows you to disable the telemetry flag. The default value is false.
appOriginAllows you to specify the application which uses the SDK. The default value is picked up from the window.location.origin class.
const robot = UiPathRobot.init();
robot.settings.portNumber = 1234;
robot.settings.pollTimeInterval = 1000;
robot.settings.disableTelemetry = true;
robot.settings.appOrigin = 'MyApp';
Add-on Settings
In order to change add-on settings, you need to change the uipath.config file from the %ProgramFiles%\UiPath\Studio folder.
The configuration file needs to contain the following:
<robotJsSettings>
    <add key="ListenerPort" value="2323" />
    <add key="TokenExpiryInDays" value="30" />
</robotJsSettings>
<robotJsSettings>
</robotJsSettings>
ListenerPortThe UiPath.RobotJS.ServiceHost.exe starts a HttpListener on the configured port and contains the information about other local listeners from the active user session on that system. Please note that the port value here needs to match the one configured in the SDK Settings.
TokenExpiryInDaysAny request coming from a new domain needs to have consent from the user to allow access of UiPath Robots from a web application. These consents are valid for the said number of days mentioned in this setting.
Default Overlay
It is possible to customize the consent screen displayed when a request is raised from a new domain. There are currently two screens that are delivered with the Robot JavaScript SDK:
Consent Prompt
The consent-prompt overlay is displayed when a request to access the UiPath Assistant is raised from a new domain.
Missing Components
The missing-components overlay is displayed when the required add-on is not present on the local machine.
Overlay messages can be configured as exemplified below.
// Consent code will be written to the console instead of showing default overlay
// Error logged to console when required components are missing insread of showing
// default error overlay
robot.on('consent-prompt', function(consentCode){ console.log(consentCode) });
robot.on('missing-components', function(){ console.log('Missing components') });
SDK Settings
class Settings {
  portNumber: number;
  appOrigin: string;
class Settings {
  portNumber: number;
  appOrigin: string;
  • Add-on Settings
  • Default Overlay
  • SDK Settings
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
