- Getting Started
- Studio
- Orchestrator
- Testing robots
- Test Manager
Test Suite User Guide
This section includes testing related activities found in the UiPath.Mobile.Automation.Activities pack. Through these activities, you can create automation for your devices, running native or web applications. You can find the activities in Studio, under Mobile Automation.
Activity |
Description |
Establishes a connection to a mobile device and provides scope for all subsequent activities. | |
Retrieves the log types from a device connected via the Mobile Device Connection | |
Retrieves the logs from a mobile device connected via the Mobile Device Connection scope activity. | |
Installs a specified app on a mobile device connected via the Mobile Device Connection scope activity. | |
Retrieves the page source from a mobile device connected via the Mobile Device Connection scope activity. | |
Manages the current app by using a user input command. | |
Sends a user input command to a specified app on the target mobile device. | |
Navigates to a deep link inside an application. | |
Opens a specified URL in the currently active web browser. | |
Retrieves the current orientation of the specified mobile device. | |
Presses a hardware button on the connected device. | |
Changes and then retrieves the orientation of the connected device. | |
Takes a screenshot of the screen of the mobile device you are using with custom dimensions specified in the Height and Width properties. | |
Returns a boolean variable that states whether a specified UI element exists. | |
Retrieves an attribute of a specified UI element. | |
Retrieves the selected item from a target UI element. | |
Extracts the text from a specified UI element and returns it as a string variable. | |
Sets the selected item on a target UI element. | |
Types the specified text into a target UI element. | |
Swipes the screen in a specified direction and for a specified amount of times. | |
Draw Pattern | Draws a path marked by multiple points on the device screen. |
Type Text | Takes the content typed through the keyboard and pastes it into the currently active UI element. |
