- Getting Started
- Introduction
- Studio
- Orchestrator
- Testing robots
- Test Manager
Test Suite User Guide
Test SuiteTM, as a solution, comprises four of UiPath®'s tools: Studio, Orchestrator, Robot, and, finally, Test Manager. Check out the diagram and information below to learn about every component, and how it works.
Component | Description |
Studio | The IDE for test automation development, enabling you to create
test cases. Studio offers you two experiences when designing test
cases within Studio:
Orchestrator | The platform that allows you to publish, centralize, and execute your tests, from Orchestrator, or using a CI/CD pipeline. |
Testing Robots | The agent connected to Orchestrator, that executes processes, including tests. |
Test Manager | The test management tool, and the native integrations that Test Manager offers. |
CI/CD Integrations | CI/CD pipelines that allow you to deploy testing projects and manage them. |
UiPath® Test Suite is the testing solution powered by the UiPath® Platform. As the visual below depicts, the UiPath® Platform does more than just empowering you to discover automation opportunities; it also provides the means to automate them. Beyond this, it offers tools for the operational context to enable you to deploy, govern, and measure the real-world impact of your robotic process automations.
Now, think of UiPath® Test Suite as a vertical slice straight through our platform:
This slice is packed with capabilities for everything from discovering tests, automating tests, running tests, to analyzing test results, and managing your testing efforts. Essentially, UiPath® Test Suite is the quality hub of our platform, acting as the backbone of both your top-notch robotic process automations and high-quality software applications. So, UiPath® Test Suite has a dual purpose:
First, UiPath® Test Suite is used by testing teams in software development to test a wide range of software applications, including web apps, mobile apps, and CRM/ERP systems like Salesforce, ServiceNow, and SAP. This is what we call application testing. Secondly, Test Suite is used by RPA teams, who are typically found in business departments such as marketing, finance, and sales, to test their robotic process automations. This is what we call RPA testing. The beauty of UiPath® Test Suite is that it's a single solution that can be leveraged for testing both software applications and robotic process automations.
In addition, think of UiPath® Test Suite as a solution, a suite of 4 tools:
First, we have UiPath® Test Manager , our test management tool. Then we have UiPath® Studio, our IDE for developing test automation. Next, we have UiPath® Orchestrator, our tool for orchestrating (cloud-based distributed) test execution. And lastly, our UiPath® Robots for performing the test execution. These 4 components come with a variety of testing capabilities for automating tests in virtually any technology, including web, desktop, API, and mobile test automation. UiPath® Test Suite also enables you to fully integrate your testing efforts into your version control tools and CI/CD pipeline(s).
It doesn't stop there. UiPath® Test Suite comes with comprehensive test data management capabilities for data-driven testing. It provides a rich set of test management capabilities, including requirements management, analytics and reporting, manual testing, and test mining capabilities – all powered by AI and tightly integrated into your ALM tools. And if you're looking to transition from legacy testing tools to UiPath® Test Suite, we offer migration assistants to ease that shift.
Best of all? All that's available both on cloud and on premises. And there you have it, in a nutshell – the range and richness of UiPath® Test Suite, designed to accelerate and streamline your testing.
Now, let's zoom out even more for a moment to see UiPath® Test Suite from a bird's-eye view. UiPath® Test Suite is versatile. It allows both tech-savvy testers and everyday business users to document test cases with UiPath® Task Capture and to create tests for virtually any technology, thanks to its low-code and coded test automation capabilities. But what about other tools you are using? UiPath® Test Suite has got that covered too. It can work smoothly with version control tools like Git, SVN, and TFS. It also teams up with build tools, for example, Jenkins. On top of that, UiPath® Test Manager, the test management tool of UiPath® Test Suite, provides native integrations to widely used ALM tools: think ServiceNow, SAP Solution Manager, Azure DevOps, Jira, and even Jira plugins like Xray.
And if there's an ALM tool we don't integrate with, our software development kit, included with UiPath® Test Manager, helps you make that integration happen. Need more? There's Planview Hub, an integration platform connecting you with more than 60 popular ALM and test management tools. And the cherry on top? All these integrations coming with Planview Hub, which we collectively call UiPath® Test Manager Connect, are included in every UiPath® Test Manager license, at no extra charge.
