test-manager
- Getting started
- Project management
- Documents
- Step 1: Installing the UiPath SAP Add-On in your SAP system
- Step 2: Configuring your SAP system
- Working with Heatmap
- Requirements
- Test sets
- Executing Tests
- Test Results
- Project operations and utilities
- Test Manager settings
- ALM tool integration
- API integration
Test Manager user guide
Last updated Aug 25, 2025
To establish a communication between UiPath Test Manager and your SAP system, create a
communication user in your SAP system for the integration with UiPath Test Manager.
Assign the necessary roles and authorizations based on your organization's internal
policies.
- The integration uses standard interfaces via RFC.
- UiPath does not require specific authorizations, except for RFC connections.
Note: If you use an RFC connection, assign the
S_RFCACL
authorization object to the communication
user.
