- Getting started
- Project management
- Project operations and utilities
- Test Manager settings
- ALM tool integration
- API integration
- Troubleshooting
Test Manager user guide
Integrate your Atlassian Jira instance to Test Manager to add defect reports, and assign stories and requirements to your tests. The integration works with all Jira project types.
To integrate Jira to Test Manager, follow these procedures:
Step 2: Configure a a Jira connection
Step 3: Configure Jira project
- Items synchronized from Jira to Test Manager are read-only except for attachments, object labels and test case links.
- Defects are synchronized from test executions in Test Manager to Jira.
All the objects that you create in Test Manager will have the identity of the Jira user used for this connection. The connection is established based on the type of Jira product that you are using. For Jira Data Center, you need to set a connection for Jira Server. For Jira Cloud, you need to configure a connection for Jira Cloud:
To understand how integration works with the help of Xray for Jira and , take a look at the following video:
The following table lists the actions that you can take to manage your Jira connections.
Action |
Description |
Procedure |
Edit |
Edit your connection settings. |
Delete |
Delete the selected connection and its associated requirements. |
