studio-web
- Getting started
- Administration
- Designing automations
- Creating an automation from an idea
- Creating a project
- How to start an automation
- Managing project files and folders
- Connecting automations to your accounts
- Configuring activities
- Managing the activities in a project
- Passing values between activities
- Iterating through items
- Managing the data in a project
- Configuring a project to use your data
- Using file and folder resources
- Using UI Automation for browser interactions
- Running and testing your projects
- Managing automations
Studio Web for Automation Suite User Guide
Last updated Sep 24, 2025
The Automation details page contains detailed
information about each project listed in the Automations page. To reach the
Automation details page, simply select the icon on the right of a project.
Dedicated buttons on the top of the page allow you to edit and share the project. Select
See more to access more options for your project:
- Project settings - Allows you to change the name and the description of the project. The window is resizable.
- Change history - Opens the change history window, where you can see details about each version of the project listed in chronological order. Selecting a version opens it in Studio Web in read-only mode.
- Duplicate - Creates a copy of the selected project.
- Open in Studio Desktop - Opens the project in Studio Desktop. If Studio is not installed on your machine, a dialog is displayed giving you the option to download and install it.
- Download - Downloads the selected project as a UIP file which can be imported in Studio Web.
Delete - Removes the selected project.
Note: Deleting a project cannot be undone.
On the right side of the Automation details page, you can find other relevant
project information:
- Collaborators - Who collaborated on the project.
- Connections used - What Integration Service connections are used in the
project. Each connection contains the following information: an icon
representing the connector, the connection name, the connection status, and
whether a connection is personal or from a shared folder. The connection status
is highlighted by the following icons:
- The Connected
icon if the connection is valid.
- The Disconnected
icon if there are issues with the connection. Select
> Fix connection on the right side of a disconnected connection to fix it. Please note that no status is available for browser connections. Select
> Manage all connection to handle your connections in the Integration Service
- The Connected
- Project Details - See the project's published status and when it was created, last modified, and last deployed.
