studio-web
Studio Web for Automation Suite User Guide
Last updated Dec 5, 2025
Common VB expressions for Validation Control
Getting the whole Extraction Result
To return the extraction result object, currently rendered by the control:
  • Using the Validation Control element
    MainPage.ValidationControl.ExtractionResultMainPage.ValidationControl.ExtractionResult
  • Using the Validation Control variable
    AppVariable.VarValidationControl.ExtractionResultAppVariable.VarValidationControl.ExtractionResult
For example:
  • Getting the field value by field name:
    AppVariable.VarValidationControl_MainPage.ExtractionResult.GetFieldByFieldName("Invoice Number").Values(0).ValueAppVariable.VarValidationControl_MainPage.ExtractionResult.GetFieldByFieldName("Invoice Number").Values(0).Value
  • Getting the field value by field index:
    AppVariable.VarValidationControl_MainPage.ExtractionResult.ResultsDocument.Fields(0).Values(0).ValueAppVariable.VarValidationControl_MainPage.ExtractionResult.ResultsDocument.Fields(0).Values(0).Value
  • Getting the list of all field names displayed in the Validation Control
    AppVariable.VarValidationControl.ExtractionResult.GetFields().Select(Function(f) f.FieldName)AppVariable.VarValidationControl.ExtractionResult.GetFields().Select(Function(f) f.FieldName)
Here is the list of methods you can use to read data from ExtractionResult:
  • .GetDocumentType()
  • .GetField()
  • .GetFieldByFieldName()
  • .GetFields()
  • .GetFieldValidatorNotes()
  • .GetFieldValidatorNotesByFieldName()
  • .GetSimpleFieldValues()
  • .GetSimpleFieldValuesByFieldName()
  • .GetTable()
  • .GetTableByTableName()
  • .GetTableFieldValue()
  • .GetTableFieldValueByTableName()
  • .GetValueCount()
  • .GetValueCountByFieldName()
Getting the taxonomy used by the control
To inspect document types, fields, or display properties:
    MainPage.ValidationControl.TaxonomyMainPage.ValidationControl.Taxonomy
    AppVariable.VarValidationControl.TaxonomyAppVariable.VarValidationControl.Taxonomy
For example:
  • Getting the list of fields in a taxonomy and save it as a source for a dropdown control:
    AppVariable.VarValidationControl_MainPage.Taxonomy.GetFields(VarValidationControl_MainPage.SelectedDocumentType).ToListSourceAppVariable.VarValidationControl_MainPage.Taxonomy.GetFields(VarValidationControl_MainPage.SelectedDocumentType).ToListSource
Here is the list of methods you can use to read data from Taxonomy:
  • .GetFields()
Getting the selected document type, as String
To bind UI elements to the curently chosen document type:
    MainPage.ValidationControl.SelectedDocumentTypeMainPage.ValidationControl.SelectedDocumentType
    AppVariable.VarValidationControl.SelectedDocumentTypeAppVariable.VarValidationControl.SelectedDocumentType
Getting the selected field object
    MainPage.ValidationControl.SelectedFieldMainPage.ValidationControl.SelectedField
    AppVariable.VarValidationControl.SelectedFieldAppVariable.VarValidationControl.SelectedField
You can further access SelectedField properties, such as .Field.FieldName, .Field.FieldType, or .Field.ValidatorNotes.
For example:
  • Getting the selected field value:
    AppVariable.VarValidationControl_MainPage.SelectedField.Field.FieldValueAppVariable.VarValidationControl_MainPage.SelectedField.Field.FieldValue
    You can further access selected field value properties, such as .FieldValue.Value, .FieldValue.Confidence, .FieldValue.OperatorConfirmed.
  • Getting the selected field all values:
    AppVariable.VarValidationControl_MainPage.SelectedField.Field.ValuesAppVariable.VarValidationControl_MainPage.SelectedField.Field.Values
  • Getting the selected field first value:
    AppVariable.VarValidationControl_MainPage.SelectedField.Field.Values(0).ValueAppVariable.VarValidationControl_MainPage.SelectedField.Field.Values(0).Value
  • Getting the selected field data type:
    AppVariable.VarValidationControl_MainPage.SelectedField.Field.FieldType.ToStringAppVariable.VarValidationControl_MainPage.SelectedField.Field.FieldType.ToString
  • Getting the selected field index:
    AppVariable.VarValidationControl_MainPage.SelectedField.FieldValueIndex.ToStringAppVariable.VarValidationControl_MainPage.SelectedField.FieldValueIndex.ToString
Getting the Validation Control properties
To read Validation Control properties:
    MainPage.ValidationControl.<PROPERTY NAME>MainPage.ValidationControl.<PROPERTY NAME>
    Controls.MainPage.ValidationControl.<PROPERTY NAME>Controls.MainPage.ValidationControl.<PROPERTY NAME>
Reading a field value from a table
  • Reading field value from a table
    AppVariable.VarValidationControl_MainPage.ExtractionResult.GetTableFieldValueByTableName(<TABLENAME>)(<COLUMN INDEX>)(<ROW INDEX>).ValueAppVariable.VarValidationControl_MainPage.ExtractionResult.GetTableFieldValueByTableName(<TABLENAME>)(<COLUMN INDEX>)(<ROW INDEX>).Value
    For example:
    AppVariable.VarValidationControl_MainPage.ExtractionResult.GetTableFieldValueByTable Name("Invoice Items")(0)(0).ValueAppVariable.VarValidationControl_MainPage.ExtractionResult.GetTableFieldValueByTable Name("Invoice Items")(0)(0).Value
Setting focus on a table cell
  • Using the Set Variable Value activity with the following expression in the Set value field
    AppVariable.VarValidationControl_MainPage.Field("Invoice Items").Field("Description", 0).SetFocusAppVariable.VarValidationControl_MainPage.Field("Invoice Items").Field("Description", 0).SetFocus
