solutions-management
  • Introduction
    • Solutions overview
    • Understanding solution concepts
    • Solution components
  • Getting started
  • Managing solution projects and packages
  • Managing solution deployments
Solutions user guide
Last updated Sep 16, 2025
Solution components
The following table lists the currently supported solution components:
Product
Solution components
Folder-level components
Tenant-level components
Action Center
  • Action catalogs
  • N/A
Apps 1
  • Apps
  • N/A
Data Service
  • N/A
  • Choice sets
  • Entities
Integration Service
  • Connections
  • Event triggers that are part of automations
  • N/A
Orchestrator
  • Assets
    • Test
    • Bool
    • Integer
    • Credential
  • Event triggers
  • Processes
    • Automation
    • Business Process
    • Web App
    • Agent
    • Test Automation
    • API
  • Queues
  • Storage buckets
    • Orchestrator
    • Azure Storage
    • Amazon S3
  • Triggers
  • Webhooks
  • Libraries
Context Grounding
  • Indexes
  • N/A
1 Installing Legacy Apps with storage buckets is not supported and results in an error if attempted.
Note:
To learn more about the properties of each Solution component, refer to their corresponding product user guide.
