Automation Suite admin guide
Last updated Oct 15, 2025
Software requirements
To access the UiPath platform, you only need an internet connection with TLS and a compatible web browser.
Browser compatibility
The following table lists the supported browsers.
Important: Internet Explorer is not supported. Please use one of the supported browsers to access our web products.
Browser
Version
Google Chrome
for Windows or MacOS
2 latest versions
Microsoft Edge Chromium
2 latest versions
Mozilla Firefox
2 latest versions
Apple Safari
for MacOS
latest version
Unlisted browsers, older versions of the listed browsers, and mobile browsers are not supported. If you use any of these excluded types of browsers, certain features may not function as expected or errors may occur.
Compatibility with other products
For information about the compatible versions of UiPath Robot and UiPath Studio, refer to the technical compatibility matrix.
Activating TLS on your machine
Make sure that you connect to the internet using TLS.
  1. On your machine, open Control Panel > Network and Internet > Internet Options.
  2. Select the Advanced tab.
  3. Scroll down to the Security section.
  4. Select the Use TLS 1.2 check box.
  5. Select Apply.
  • Browser compatibility
  • Compatibility with other products
  • Activating TLS on your machine
