Automation Suite release notes
2023.4.7
Release date: June 27, 2024
We have introduced a new prerequisite check to optimize the experience of installing and configuring Automation Suite. Automation Suite now checks if the external objectstore supports POST requests to buckets via pre-signed URLs. Document Understanding requires POST request support to download files from the buckets.
4.0.2
We're happy to announce various fixes and improvements that ensure an even more accurate estimate of the hardware requirements for any Automation Suite deployment. In particular, you get more useful requirements for the multi-node profile and the multi-zonal setup. Also, it now takes a single click to share the UiPath Automation Suite Install Sizing Calculator URL along with your currently selected configuration.
If you want to take the UiPath Automation Suite Install Sizing Calculator for a spin, see Capacity planning.
Erratum - added August, 2024: We have fixed an issue causing the
snapshot-controller-crds
pod to remain in the CrashLoopBackOff state after an RKE2 upgrade. This issue occurred due to a conflict between the newly installedsnapshot-controller
and the existing one during the RKE2 upgrade. -
When generating the support bundle, an incorrect FQDN was used for AKS on Azure Government. We have fixed the issue.
redis-cluster-0
pod to get stuck in the terminating state when you perform a node drain in non-HA Redis scenarios. To address the problem,
you must force delete the pod using the following command:
kubectl -n redis-system delete pod redis-cluster-0 --force
We fixed the issue in Automation Suite 2023.4.10.
Erratum - added December 18, 2024: An Insights annotation issue blocks the Automation Suite installer. We fixed the issue in Automation Suite 2023.4.10.
Erratum - added December 18, 2024: The RKE2 log collector runs indefinitely for some system commands. We fixed the issue in Automation Suite 2023.4.10.
System.Net.Http.HttpRequestException: The proxy tunnel request to proxy 'http://<proxyFQDN>:8080/' failed with status code '404'.
To fix the issue, see the Troubleshooting section.
rke2-server
service is shut down without executing the rke2-killall.sh
script. We fixed this issue in Automation Suite 2023.4.9.
Erratum - added August 14, 2024: An issue affects the support bundle generation when using an external OCI registry in an offline environment. Under these conditions, the generated support bundle lacks historical logs and cannot upload to any selected external object storage. To fix this issue, see the Troubleshooting section.
ListBucket API
prerequisite check fails when using an external objectstore. However, AI Center and Task Mining do not use the ListBucket API
permission. We removed the unnecessary check in Automation Suite 2023.4.8.
Erratum - added August 14, 2024: You cannot enable SSO for ArgoCD due to an issue with the Dex image versions. We fixed the issue in Automation Suite 2023.4.8.
containerd
issue, the deployment of ML skills fails as a token expires before larger image downloads can be completed, especially under
conditions of slower network connectivity.
To address this isssue, see the Troubleshooting section.
Erratum - added February 13, 2025: An issue affects the functionality of email alerts configuration and the setup of multiple receivers after upgrading from Automation Suite 2022.10. To address this issue, see Troubleshooting.
This issue is fixed in Automation Suite 2023.4.11.
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
DISCOVER | BUILD | MANAGE | ENGAGE |
AI Center 2023.4.7 | Action Center 2023.4.7 | ||
Task Mining 2023.4.7 | AI Computer Vision 2023.4.7 | Insights 2023.4.7 | Apps 2023.4.7 |
Document Understanding 2023.4.7 | Orchestrator 2023.4.8 | ||
Test Manager 2023.4.6 | |||
This Automation Suite release bundles the following internal components:
Component |
Version |
RKE2 |
1.28.7 |
ArgoCD |
2.10.9 |
logging-operator |
4.6.0 |
logging-operator-logging |
4.6.0 |
gatekeeper |
3.16.0 |
rook-ceph |
1.9.4 |
prometheus-pushgateway |
2.12.0 |
cert-manager |
1.14.5 |
rancher-istio |
102.5.0-up1.19.6 |
rancher-logging |
103.0.0-up3.17.10 |
rancher-logging-crd |
103.0.0-up3.17.10 |
rancher-monitoring-crd |
103.1.0-up45.31.1 |
rancher-gatekeeper-crd |
103.1.0-up3.13.0 |
rancher-gatekeeper |
103.1.0-up3.13.0 |
rancher-monitoring |
103.1.0-up45.31.1 |
longhorn |
1.5.5 |
longhorn-crd |
1.1.100 |
reloader |
1.0.95 |
csi-driver-smb |
1.14.0 |
velero |
6.2.0 |
redis-operator |
7.4.2-12 |
redis-cluster |
7.4.2-129 |
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
- New prerequisite check
- Updated Podman version
- Improved UiPath Automation Suite Install Sizing Calculator
- Bug fixes
- Known issues
- Node maintenance issue in non-HA Redis
- Insights annotation issue blocks installer
- RKE2 log collector runs indefinitely
- Redis failures due to inconsistent password updates
- Intermittent not ready reports from agent machines
- Weak ciphers in TLS 1.2
- Unnecessary ListBucket API prerequisite check fails for external objectstore
- Cannot enable SSO for ArgoCD
- ML skill deployment failure due to token expiry
- Email alerts configuration failure post upgrade
- Deprecation timeline
- Bundling details
- Product versions
- Internal third-party component versions
- Migration tool version
