  • Getting started
    • About this guide
    • Available resources
    • API endpoint URL structure
    • Enumeration List
  • Authentication
  • Scopes and permissions
  • Platform Management APIs
Automation Suite API guide
Last updated Feb 24, 2025
Update Settings
As a host or organization administrator, use this endpoint to update existing settings or create new settings for a the specified organization and/or user ID.
API Endpoint
PUT /identity_/api/Setting
Scopes
Requires the following scopes:
  • PM.Setting
  • PM.Setting.Write
Request Headers
--header 'Content-Type: application/json'--header 'Authorization: Bearer {access_token}'\
Note: To obtain the {access_token}, make sure to authenticate through one of the methods described here.
Request Body
The request body contains the organization ID and the setting keys you want to update.
  "settings": [
      "key": "string",
      "value": "string"
  "partitionGlobalId": "string",
  "userId": "string"
  "settings": [
      "key": "string",
      "value": "string"
  "userId": "string"
Responses
200 OK
The settings are updated with the information you provided.
Example Request
Let's say you gathered all the information needed to build the API call.
  • Your {baseURL} is: https://{yourDomain}/{organizationName}/{tenantName}/
  • Your {access_token} is: 1234 (for length considerations).
  • The {partitionGlobalId} is: magic-7
  • You want to update the authentication settings, so you log in as a host admin.
The call should resemble the following example (cURL):
curl --location --request PUT 'https://{yourDomain}/{organizationName}/{tenantName}/identity_/api/Setting' \)\)
--header 'Authorization: Bearer 1234' \)\)
--data-raw '
    "settings": [
            "key": "Auth.Password.DefaultExpirationDays",
            "value": "0"
            "key": "Auth.Password.PasswordComplexity",
             "value": "{\"hasSpecialCharacter\":false,\"hasLowercase\":true,\"hasUppercase\":false,\"hasDigit\":true,\"Length\":\"10\"}"
            "key": "Auth.Password.PreviousUseLimit",
            "value": "1"
            "key": "Auth.Password.ShouldChangePasswordAfterFirstLogin",
            "value": "true"
            "key": "Auth.UserLockOut.DefaultAccountLockoutSeconds",
            "value": "0"
            "key": "Auth.UserLockOut.IsEnabled",
            "value": "false"
            "key": "Auth.UserLockOut.MaxFailedAccessAttemptsBeforeLockout",
            "value": "2"
    "partitionGlobalId": "magic-7"
}'curl --location --request PUT 'https://{yourDomain}/{organizationName}/{tenantName}/identity_/api/Setting' \)\)
--data-raw '
    "settings": [
            "value": "0"
            "value": "1"
            "value": "true"
            "value": "0"
            "value": "false"
            "value": "2"
Here is the response for a successful call:
        "id": 4,
        "value": "0",
        "partitionGlobalId": "magic-7",
        "userId": null
        "id": 1,
        "value": "{\"HasDigit\":true,\"HasLowercase\":true,\"HasSpecialCharacter\":false,\"HasUppercase\":false,\"Length\":10,\"RegexComplexity\":{\"HasDigitRegex\":\"(?=.*\\\\d)\",\"HasLowercaseRegex\":\"(?=.*[a-z])\",\"HasSpecialCharacterRegex\":\"(?=.*[^a-zA-Z\\\\d])\",\"HasUppercaseRegex\":\"(?=.*[A-Z])\",\"LengthRegex\":\"{10,}\",\"Regex\":\"(?=.*\\\\d)(?=.*[a-z]).{10,}\"}}",
        "userId": null
        "id": 3,
        "value": "1",
        "userId": null
        "id": 2,
        "value": "true",
        "userId": null
        "id": 26,
        "value": "0",
        "userId": null
        "id": 27,
        "value": "false",
        "userId": null
        "id": 28,
        "value": "2",
        "userId": null
        "id": 4,
        "value": "0",
        "userId": null
        "id": 1,
        "userId": null
        "id": 3,
        "value": "1",
        "userId": null
        "id": 2,
        "value": "true",
        "userId": null
        "id": 26,
        "value": "0",
        "userId": null
        "id": 27,
        "value": "false",
        "userId": null
        "id": 28,
        "value": "2",
        "userId": null
  • API Endpoint
  • Scopes
  • Request Headers
  • Request Body
  • Responses
  • 200 OK
  • Example Request
