- Getting started
- Authentication
- Scopes and permissions
- Platform Management APIs
Delete Robot Accounts
OUT OF SUPPORT
Automation Suite API guide
Last updated Feb 24, 2025
Deletes multiple robot accounts from an organization, based on the organization ID.
DELETE
https://{yourDomain}/{organizationName}/identity_/api/RobotAccount/{partitionGlobalId}
Note: To obtain the
{access_token}
, make sure to authenticate through one of the methods described here.
Path param |
Data type |
Description |
(required) |
String |
The ID of the organization you want to retrieve the robot accounts for. |
The request body contains the list of robot accounts IDs you want to bulk delete from the organization.
"robotAccountIDs": [
"string",
"string"
"string",
"string"
Let's say you gathered all the information needed to build the API call.
- Your
{baseURL}
is:https://{yourDomain}/{organizationName}/{tenantName}/
Your
{access_token}
is:1234
(for length considerations). - The
{partitionGlobalId}
is:magic-7
The robot accounts you want to delete have the following IDs:
- Bot1:
11-xy
- Bot2:
22-tz
- Bot1:
The call should resemble the following example (cURL):
curl --location --request DELETE 'https://{yourDomain}/{organizationName}/{tenantName}/identity_/api/RobotAccount/magic-7' \
--data-raw '{
"11-xy",
"22-tz"
--data-raw '{
"11-xy",
"22-tz"
