- Release Notes
- Getting Started
- Permissions
- Starting as
- Admin Console
- Workspace
- Explore
- Dashboards
- Share Idea or Automation
- My Tasks
- My Tasks Overview
- Reviewing My Assigned Tasks
- Complete Tasks
- Notifications
- Email Notifications
- Resources
- Studio Integration
- Task Capture Integration
- Automation Store
- Additional Resources
Automation Hub User Guide
Last updated Oct 17, 2024
linkTo review the tasks assigned to you follow the below steps:
- Access My Tasks > Incomplete view.
Search for the task you want to complete.
Note: The first column of the table called Task provides a description of the action you are required to do. You can use the filter associated with this column to easily review tasks that require the same type of action. - Click the corresponding three-dotted icon from the Actions column.
Use the View option to quickly access the page where you can complete the action.
For example, if a task related to an automation or idea profile was assigned to you, clicking the View Auomation Profile option opens the Automation or Idea Profile page allowing you to complete the assigned action.
- Once you completed the assigned action return to My task page > Incomplete view > click the corresponding three-dotted icon from the Actions column > select Clear Task.
The task is moved to My Task > Completed view.
