Automation Hub API Guide
Last updated Nov 11, 2025
Authentication to the Automation Hub API
Automation Hub API authentication uses a simple static Bearer token in the header of each request. For information on how to create or find a Token, see Generate your Token from Automation Hub.
Example request (to the Auth Info endpoint):
GET https://cloud.uipath.com/{orgName}/{tenantName}/automationhub_/api/v1/openapi/authinfo
Authorization: Bearer 46b6c342-3ab4-11e9-9c19-37a2344a67e8/ce91aa04-fc61-49e9-bec5-cb237efb4bda
x-ah-openapi-auth: openapi-tokenGET https://cloud.uipath.com/{orgName}/{tenantName}/automationhub_/api/v1/openapi/authinfo
The x-ah-openapi-auth value of openapi-token is static. The Authorization Bearer token is created by concatenating Tenant ID, the character /, and a Token.
E.g. 46b6c342-3ab4-11e9-9c19-37a2344a67e8/ce91aa04-fc61-49e9-bec5-cb237efb4bda is composed of:
  • Tenant ID: 46b6c342-3ab4-11e9-9c19-37a2344a67e8
  • Concatenating Character: /
  • Token: ce91aa04-fc61-49e9-bec5-cb237efb4bda
Similar headers would be used in a request to any other Automation Hub API endpoint.
