- Release notes Public Sector
- Getting Started
- Permissions
- Starting as
- Admin Console
- Workspace
- Explore
- Share Idea or Automation
- Dashboards
- My Tasks
- Notifications
- Email Notifications
- Resources
- Studio Integration
- Task Capture Integration
- Automation Store
- Additional Resources
Automation Hub User Guide for Public Sector
You can edit the settings of an idea flow by accessing any idea flow and selecting the pencil icon next to it. You can also access the Settings option from the Actions menu, in the right side of the page. In the dialog box that appears you can edit the following basic information:
- Idea flow title (mandatory)
- Description
- Permissions
- Advanced
In the Permissions area, you can set the specific roles for the following permissions:
- Who can submit ideas in the flow (mandatory to have at least one role selected).
- Who can edit ideas in the flow (mandatory to have at least one role selected).
- Who can forcibly update any idea's status to any other phase and status.
- Who can delete ideas in this flow (mandatory to have at least one role selected).
- Who can change the assessment version in the automation profile.
In the table below, you can find the old role permissions that are being replaced by the new permissions found in Idea flow customization. This helps you assign permissions differently for every idea flow, instead of the same set of permissions for a specific role available for all idea flows.
The new permission names available in Idea flow customization setting | Old role permissions found in Roles page |
Who can submit ideas in the flow | Submit an employee-driven idea / Submit a CoE-driven idea / Submit a change request / Share an automation |
Who can edit ideas in the flow | Edit all details of any Idea |
Who can forcibly update any idea's status to any other phase and status | Update the Phase and Status of any idea |
Who can delete ideas in this flow (mandatory) | Delete any Idea |
Who can change the assessment version in the automation profile | Change the assessment version of any idea |
Example: Before Idea flow customization, to make sure a user had access to Edit all details of any Idea, you had to check that the respective permission was assigned to his tenant role in the Roles page, or create a new role with that permission checked. Now, to make sure a specific tenant role has access to Edit all details of any Idea you just need to select the role you wish to be able to do that, in the Who can edit ideas in the flow drop-down list from the Permissions area in the Idea Flow Settings.
- Submission form: the Idea type field won't show the flow’s name in the drop-down;
- Users can't submit ideas on the flow through Automation Hub interface;
- Ideas submitted on the flow will be collected through OpenAPI from other tools/products.
By toggling the This is a change request idea flow setting to ON, the Assessments visibility section is impacted as:
- Only four assessment types are available: Overview, Change Request, Execution assessment and Feedback assessment.
- The Admin user can't delete these assessment types.
- The Admin user can't add more assessment types.
After configuring the settings, select Save to update the settings of your idea flow.
