- Open API
- Introduction to Automation Hub API
- API References
- Generate your Token from Automation Hub
- Authenticating to Your Automation Hub Tenant
- Retrieve Automation Idea in Idea Phase Awaiting Review Status
- Retrieve the Cost Benefit Analysis for a Specific Idea
- Update Automation Idea Phase and Status
- Power BI Integration Video Tutorial
- Service Now Outbound Integration Video Tutorial
- Retrieve a User Account
- Update Account Details for Employees from Automation Hub
- Inactivate User Accounts that are Not Part of the Company
- Input for Automation Pipeline
- Input for Submission Type
- Input for Phase
- Input for Status
- Input for Phase and Status Update
- Input for Business Unit
- Input for Applications
- Input for Category
- Input for Cost Benefit Analysis
- Input for High Level Assessment
- Input for Detailed Assessment
- Input for Automation Idea Creation Date
- Input for Users
- Input for User Status
- User Status Table
- Input for Collaborators
- Output Dictionary
- Automation Hub Open API Power Query Data Parsing
- Automation Hub Custom Connector - Preview
Automation Hub API Guide for Public Sector
Used for Submitting the Employee-driven Ideas
Key |
Value |
Use Case |
Mandatory? |
How rule-based is your task? = rules |
GET and POST request parameters |
Yes |
How would you describe the input data for your task/process? = input_type |
Yes |
How would you describe the structure of your input data? = input_quality |
Yes |
Are you aware of any expected changes to the way you currently perform the activity or process in the following 6 months? = stability |
Yes |
Do you have any documentation regarding this process/activity?= documentation |
Yes |
The Idea submittersubmitter |
Enter the submitter email address. |
Yes | |
The idea assigned Process Ownerowner |
Enter the Process Owner email address. |
Yes | |
Automation Idea Name = process_name |
Enter the name of the idea using the template. |
POST request parameter |
Yes |
Description = process_description |
Enter the idea description using the template. |
Yes |
Automation Idea Area = category_id |
You can easily extract Category ID by using the GET category call. |
Yes |
"process_name": "InvoiceProcessing",
"process_description": "Invoice data entry",
"category": 717,
"rules": 4,
"input_type": 3,
"input_quality": 5,
"stability": 4,
"documentation": 5,
"submitter": "[email protected]",
"owner": mary.doe@email.com1
"category": 717,
"rules": 4,
"input_type": 3,
"input_quality": 5,
"stability": 4,
"documentation": 5,
"owner": [email protected]
UI Correspondent: Submit an Idea
