test-manager
- Getting started
- Project management
- Project operations and utilities
- Test Manager settings
- ALM tool integration
- API integration
- Troubleshooting
Automation project configuration
Test Manager user guide
Last updated Apr 23, 2025
Navigate to the Automation tab within your Project Settings to specify a default Orchestrator folder for your project. This allows you to execute test cases only from specific packages and versions found within the chosen folder.
Only users assigned the roles of Test Manager Administrator at the tenant level or Project Owner at the project level have the ability to set the default Orchestrator folder.
To assign a default Orchestrator folder to your project, perform the following
steps:
- Select the Default Folder dropdown list.
- Select your preferred Orchestrator folder.
- Select Save to confirm
your changes.
The selected folder is displayed and will be used for all your test sets.
Note: The Default Folder dropdown list only
displays the Orchestrator folders to which you have access.
