studio
Studio User Guide
Last updated Sep 3, 2025
Check if ChromeNativeMessaging.exe is running
The ChromeNativeMessaging.exe enables communication between the UiPath Extension for Edge and the UiPath Studio/Robot.
  1. Open Microsoft Edge.
  2. Open Task Manager.
  3. Check if the ChromeNativeMessaging.exe process is running.
  4. If the process is not running:
    • Make sure the extension is installed. For more information on how to install it, check the docs page.
    • Check if there are Group Policies affecting ChromeNativeMessaging.exe. See the docs page for more information.
    • Check if the ComSpec environment variable is defined correctly.
