solutions-management
- Introduction
- Getting started
- Managing solution projects and packages
- Creating a solution project
- Editing a published solution project
- Transporting a solution package
- Checking the package status
- Managing solution deployments
Solutions user guide
Last updated Dec 5, 2025
You can transport solutions from an environment to another by downloading and uploading solution packages.
To download a solution package, take the following steps:
- Select the Solutions tab at tenant level.
- Find your solution package and access its corresponding three-dot button, then Download latest version. This allows you to download and share an archive containing the solution package with others.
To upload a solution package to your tenant, take the following steps:
In the Solutions view, select the desired tenant.
Select Upload solution package. Add your files in the newly open panel.
Important:Successful package uploading on a tenant requires that all resources contained in the package match the enabled services for that specific tenant. If any services are disabled, you have to wait for 30 minutes after enabling them before trying to upload the package again.
