solutions-management
  • Introduction
    • Getting started
    • Understanding the solution development lifecycle
    • Solution components - Studio Web and Orchestrator
    • Overview of the Solutions UI
    • Developing automations with and without solutions
    • Solutions feature availability
  • Managing solution projects and packages
  • Managing solution deployments
  • Best practices
Solutions user guide
Last updated May 20, 2026
While both workflows target solution deployment (both through Studio Web and Orchestrator), not all solution components have equal support in Studio Web, while some components are only supported via Orchestrator.
For each major product component, the tables below highlight what components are supported in each workflow:
Note:
Studio Web also supports additional solution resources (such as business rules, dependencies, and task catalogs) that are automatically packaged with automation projects but are not deployed as standalone solution components. For more information on those resources, see Studio Web - Designing solutions.
UiPath platform resources that can be packaged, transported and deployed as a solution
Component (product)When designing the solution in Studio Web (recommended)When creating the solution package from Orchestrator
Action Center - Task Catalog
Apps
Data Service - Entities & Choicesets✅ (only as a dependency of an already published VB App that is referenced in the Solution)
Integration Service - Connections
Integration Service - Custom connectors
Orchestrator - Assets (Test, Bool, Integer, Credential)
Orchestrator - Processes (Robotic Process Automation, Business Process, Web App, Agent, Test Automation, API)
Orchestrator - Queues
Orchestrator - Storage buckets (Orchestrator, Azure, Amazon S3)
Orchestrator - Webhooks
Orchestrator - Libraries
Context Grounding (Indexes)
The table below also includes a more granular breakdown of what Orchestrator and Integration Service triggers can be used.
Triggers (Product or Type)When designing the solution in Studio Web (recommended)When creating the solution package from Orchestrator
Orchestrator
→ Time
→ Queue
→ API
→ Events
Integration Service
→ Events
Note:
Only one trigger per entry point is supported. Triggers are not visible in the deployment configuration in Studio Web; they become visible and configurable when deploying from Solutions in Orchestrator.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
