Last updated Aug 25, 2025
Downloading the installation packages
This page provides a list of download links for all the artifacts you may need to install or configure Automation Suite on EKS/AKS. Make sure to select the version of the artifacts you target.
uipathctl
Required. uipathctl is a UiPath® command-line tool that allows you to run commands against Automation Suite Kubernetes hosted on Azure Kubernetes Service (AKS) and Amazon Elastic Kubernetes Service (EKS). You can use uipathctl to check prerequisites in your environment, install Automation Suite, configure and manage it from a single unified CLI.
Note:
Currently, uipathctl is only compatible with the x86 architecture. You cannot run uipathctl on machines based on the ARM architecture, such as Macs with Apple Silicon (M series) CPUs.
2023.10.10
To download uipathctl for Automation Suite 2023.10.10, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.10/uipathctl-2023.10.10-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.10/uipathctl-2023.10.10-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.10/uipathctl-2023.10.10-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.10/uipathctl-2023.10.10-windows-amd64.tar.gz
  • MacOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.10/uipathctl-2023.10.10-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.10/uipathctl-2023.10.10-darwin-amd64.tar.gz
2023.10.9
To download uipathctl for Automation Suite 2023.10.9, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.9/uipathctl-2023.10.9-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.9/uipathctl-2023.10.9-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.9/uipathctl-2023.10.9-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.9/uipathctl-2023.10.9-windows-amd64.tar.gz
  • MacOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.9/uipathctl-2023.10.9-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.9/uipathctl-2023.10.9-darwin-amd64.tar.gz
2023.10.8
To download uipathctl for Automation Suite 2023.10.8, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.8/uipathctl-2023.10.8-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.8/uipathctl-2023.10.8-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.8/uipathctl-2023.10.8-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.8/uipathctl-2023.10.8-windows-amd64.tar.gz
  • MacOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.8/uipathctl-2023.10.8-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.8/uipathctl-2023.10.8-darwin-amd64.tar.gz
2023.10.7
To download uipathctl for Automation Suite 2023.10.7, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.7/uipathctl-2023.10.7-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.7/uipathctl-2023.10.7-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.7/uipathctl-2023.10.7-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.7/uipathctl-2023.10.7-windows-amd64.tar.gz
  • MacOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.7/uipathctl-2023.10.7-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.7/uipathctl-2023.10.7-darwin-amd64.tar.gz
2023.10.6
To download uipathctl for Automation Suite 2023.10.6, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.6/uipathctl-2023.10.6-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.6/uipathctl-2023.10.6-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.6/uipathctl-2023.10.6-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.6/uipathctl-2023.10.6-windows-amd64.tar.gz
  • MacOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.6/uipathctl-2023.10.6-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.6/uipathctl-2023.10.6-darwin-amd64.tar.gz
2023.10.5
To download uipathctl for Automation Suite 2023.10.5, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.5/uipathctl-2023.10.5-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.5/uipathctl-2023.10.5-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.5/uipathctl-2023.10.5-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.5/uipathctl-2023.10.5-windows-amd64.tar.gz
  • MacOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.5/uipathctl-2023.10.5-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.5/uipathctl-2023.10.5-darwin-amd64.tar.gz
2023.10.4
To download uipathctl for Automation Suite 2023.10.4, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.4/uipathctl-2023.10.4-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.4/uipathctl-2023.10.4-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.4/uipathctl-2023.10.4-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.4/uipathctl-2023.10.4-windows-amd64.tar.gz
  • MacOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.4/uipathctl-2023.10.4-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.4/uipathctl-2023.10.4-darwin-amd64.tar.gz
2023.10.3
To download uipathctl for Automation Suite 2023.10.3, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.3/uipathctl-2023.10.3-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.3/uipathctl-2023.10.3-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.3/uipathctl-2023.10.3-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.3/uipathctl-2023.10.3-windows-amd64.tar.gz
  • MacOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.3/uipathctl-2023.10.3-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.3/uipathctl-2023.10.3-darwin-amd64.tar.gz
2023.10.2
To download uipathctl for Automation Suite 2023.10.2, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.2/uipathctl-2023.10.2-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.2/uipathctl-2023.10.2-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.2/uipathctl-2023.10.2-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.2/uipathctl-2023.10.2-windows-amd64.tar.gz
  • MacOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.2/uipathctl-2023.10.2-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.2/uipathctl-2023.10.2-darwin-amd64.tar.gz
2023.10.1
To download uipathctl for Automation Suite 2023.10.1, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.1/uipathctl-2023.10.1-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.1/uipathctl-2023.10.1-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.1/uipathctl-2023.10.1-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.1/uipathctl-2023.10.1-windows-amd64.tar.gz
  • MacOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.1/uipathctl-2023.10.1-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.1/uipathctl-2023.10.1-darwin-amd64.tar.gz
2023.10.0
To download uipathctl for Automation Suite 2023.10.0, run one of the following commands, depending on your OS:
  • Linux:
    wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.0/uipathctl-2023.10.0-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.0/uipathctl-2023.10.0-linux-amd64.tar.gz
  • Windows:
    wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.0/uipathctl-2023.10.0-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.0/uipathctl-2023.10.0-windows-amd64.tar.gz
  • MacOS:
    wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.0/uipathctl-2023.10.0-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.0/uipathctl-2023.10.0-darwin-amd64.tar.gz
versions.json
Required. Needed to perform prerequisite checks and installation steps.
2023.10.10
To download versions.json for Automation Suite 2023.10.10, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.10/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.10/versions.json
2023.10.9
To download versions.json for Automation Suite 2023.10.9, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.9/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.9/versions.json
2023.10.8
To download versions.json for Automation Suite 2023.10.8, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.8/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.8/versions.json
2023.10.7
To download versions.json for Automation Suite 2023.10.7, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.7/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.7/versions.json
2023.10.6
To download versions.json for Automation Suite 2023.10.6, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.6/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.6/versions.json
2023.10.5
To download versions.json for Automation Suite 2023.10.5, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.5/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.5/versions.json
2023.10.4
To download versions.json for Automation Suite 2023.10.4, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.4/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.4/versions.json
2023.10.3
To download versions.json for Automation Suite 2023.10.3, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.3/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.3/versions.json
2023.10.2
To download versions.json for Automation Suite 2023.10.2, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.2/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.2/versions.json
2023.10.1
To download versions.json for Automation Suite 2023.10.1, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.1/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.1/versions.json
2023.10.0
To download versions.json for Automation Suite 2023.10.0, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.0/versions.jsonwget -O ~/versions.json https://download.uipath.com/automation-suite/2023.10.0/versions.json
kubectl
Optional. Make sure that kubectl matches the version of your cluster.
To download kubectl, see Kubernetes documentation.
UiPath.OrganizationMigrationApp
The UiPath.OrganizationMigrationApp tool helps you perform operations such as move the Identity data of all tenants from standalone to Automation Suite and merge organizations.
To check which UiPath.OrganizationMigrationApp version is compatible with your environment, see Compatibility matrix.
2023.10.10
  • Linux
    To download UiPath.OrganizationMigrationApp on a Linux machine, run the following command in the terminal:
    wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.10-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.10-linux.zip
  • Windows
    To download UiPath.OrganizationMigrationApp on a Windows machine, click here.
2023.10.9
  • Linux
    wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.9-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.9-linux.zip
  • Windows
2023.10.8
  • Linux
    wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.8-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.8-linux.zip
  • Windows
2023.10.7
  • Linux
    To download UiPath.OrganizationMigrationApp on a Linux machine, run the following command on the terminal:
    wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.7-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.7-linux.zip
  • Windows
2023.10.6
  • Linux
    wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.6-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.6-linux.zip
  • Windows
2023.10.5
  • Linux
    wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.5-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.5-linux.zip
  • Windows
2023.10.4
  • Linux
    wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.4-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.4-linux.zip
  • Windows
2023.10.2
  • Linux
    wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.2-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.2-linux.zip
  • Windows
2023.10.1
  • Linux
    wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.1-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.1-linux.zip
  • Windows
2023.10.0
  • Linux
    wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.0-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2023.10.0-linux.zip
  • Windows
as-cmk.tar.gz
as-cmk.tar.gz contains the container images and deployment manifests of UiPath® Shared Capabilities and UiPath® Product.
If you opt for the offline installation profile, you must download as-cmk.tar.gz. If you choose the online installation profile, Kubernetes will pull all the container images and deployment manifests directly from the container registry hosted in UiPath® servers.
as-cmk.tar.gz is required during installation and upgrade.
2023.10.10
https://download.uipath.com/automation-suite/2023.10.10/as-cmk-2023.10.10.tar.gz
For the checksum file, click here.
  • Linux:
    To download as-cmk.tar.gz on a Linux machine, run the following command from the terminal:
    wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.10/as-cmk-2023.10.10.tar.gzwget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.10/as-cmk-2023.10.10.tar.gz
  • Windows:
    To download as-cmk.tar.gz, click here and rename the file to as-cmk.tar.gz.
2023.10.9
https://download.uipath.com/automation-suite/2023.10.9/as-cmk-2023.10.9.tar.gz
  • Linux:
    wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.9/as-cmk-2023.10.9.tar.gzwget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.9/as-cmk-2023.10.9.tar.gz
  • Windows:
2023.10.8
https://download.uipath.com/automation-suite/2023.10.8/as-cmk-2023.10.8.tar.gz
  • Linux:
    wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.8/as-cmk-2023.10.8.tar.gzwget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.8/as-cmk-2023.10.8.tar.gz
  • Windows:
2023.10.7
https://download.uipath.com/automation-suite/2023.10.7/as-cmk-2023.10.7.tar.gz
  • Linux:
    wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.7/as-cmk-2023.10.7.tar.gzwget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.7/as-cmk-2023.10.7.tar.gz
  • Windows:
2023.10.6
https://download.uipath.com/automation-suite/2023.10.6/as-cmk-2023.10.6.tar.gz
  • Linux:
    wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.6/as-cmk-2023.10.6.tar.gzwget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.6/as-cmk-2023.10.6.tar.gz
  • Windows:
2023.10.5
https://download.uipath.com/automation-suite/2023.10.5/as-cmk-2023.10.5.tar.gz
  • Linux:
    wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.5/as-cmk-2023.10.5.tar.gzwget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.5/as-cmk-2023.10.5.tar.gz
  • Windows:
2023.10.4
https://download.uipath.com/automation-suite/2023.10.4/as-cmk-2023.10.4.tar.gz
  • Linux:
    wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.4/as-cmk-2023.10.4.tar.gzwget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.4/as-cmk-2023.10.4.tar.gz
  • Windows:
2023.10.3
https://download.uipath.com/automation-suite/2023.10.3/as-cmk-2023.10.3.tar.gz
  • Linux:
    wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.3/as-cmk-2023.10.3.tar.gzwget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.3/as-cmk-2023.10.3.tar.gz
  • Windows:
2023.10.2
https://download.uipath.com/automation-suite/2023.10.2/as-cmk-2023.10.2.tar.gz
  • Linux:
    wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.2/as-cmk-2023.10.2.tar.gzwget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.2/as-cmk-2023.10.2.tar.gz
  • Windows:
2023.10.1
https://download.uipath.com/automation-suite/2023.10.1/as-cmk-2023.10.1.tar.gz
  • Linux:
    wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.1/as-cmk-2023.10.1.tar.gzwget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.1/as-cmk-2023.10.1.tar.gz
  • Windows:
2023.10.0
https://download.uipath.com/automation-suite/2023.10.0/as-cmk-2023.10.0.tar.gz
  • Linux:
    wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.0/as-cmk-2023.10.0.tar.gzwget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2023.10.0/as-cmk-2023.10.0.tar.gz
  • Windows:
mirror-registry.sh
mirror-registry.sh is required to configure an external Docker registry.
2023.10.10
https://download.uipath.com/automation-suite/2023.10.10/mirror-registry.sh
  • Linux:
    To download mirror-registry.sh on a Linux machine, run the following command from the terminal:
    wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.10/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.10/mirror-registry.sh
  • Windows:
    To download mirror-registry.sh on a Windows machine, click here.
2023.10.9
https://download.uipath.com/automation-suite/2023.10.9/mirror-registry.sh
  • Linux:
    wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.9/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.9/mirror-registry.sh
  • Windows:
2023.10.8
https://download.uipath.com/automation-suite/2023.10.8/mirror-registry.sh
  • Linux:
    wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.8/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.8/mirror-registry.sh
  • Windows:
2023.10.7
https://download.uipath.com/automation-suite/2023.10.7/mirror-registry.sh
  • Linux:
    wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.7/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.7/mirror-registry.sh
  • Windows:
2023.10.6
https://download.uipath.com/automation-suite/2023.10.6/mirror-registry.sh
  • Linux:
    wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.6/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.6/mirror-registry.sh
  • Windows:
2023.10.5
https://download.uipath.com/automation-suite/2023.10.5/mirror-registry.sh
  • Linux:
    wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.5/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.5/mirror-registry.sh
  • Windows:
2023.10.4
https://download.uipath.com/automation-suite/2023.10.4/mirror-registry.sh
  • Linux:
    wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.4/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.4/mirror-registry.sh
  • Windows:
2023.10.3
https://download.uipath.com/automation-suite/2023.10.3/mirror-registry.sh
  • Linux:
    wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.3/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.3/mirror-registry.sh
  • Windows:
2023.10.2
https://download.uipath.com/automation-suite/2023.10.2/mirror-registry.sh
  • Linux:
    wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.2/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.2/mirror-registry.sh
  • Windows:
2023.10.1
https://download.uipath.com/automation-suite/2023.10.1/mirror-registry.sh
  • Linux:
    wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.1/mirror-registry.shwget -O mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.1/mirror-registry.sh
  • Windows:
2023.10.0
https://download.uipath.com/automation-suite/2023.10.0/mirror-registry.sh
  • Linux:
    wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.0/mirror-registry.shwget -O mirror-registry.sh https://download.uipath.com/automation-suite/2023.10.0/mirror-registry.sh
  • Windows:
hydrate-registry.sh
hydrate-registry.sh is required for configuring your external OCI-compliant registry for offline installations in the Automation Suite.
2023.10.10
https://download.uipath.com/automation-suite/2023.10.10/hydrate-registry.sh
  • Linux:
    To download hydrate-registry.sh on a Linux machine, run the following command from the terminal:
    wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.10/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.10/hydrate-registry.sh
  • Windows:
    To download hydrate-registry.sh on a Windows machine, click here.
2023.10.9
https://download.uipath.com/automation-suite/2023.10.9/hydrate-registry.sh
  • Linux:
    wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.9/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.9/hydrate-registry.sh
  • Windows:
2023.10.8
https://download.uipath.com/automation-suite/2023.10.8/hydrate-registry.sh
  • Linux:
    wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.8/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.8/hydrate-registry.sh
  • Windows:
2023.10.7
https://download.uipath.com/automation-suite/2023.10.7/hydrate-registry.sh
  • Linux:
    wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.7/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.7/hydrate-registry.sh
  • Windows:
2023.10.6
https://download.uipath.com/automation-suite/2023.10.6/hydrate-registry.sh
  • Linux:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.6/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.6/hydrate-registry.sh
2023.10.5
https://download.uipath.com/automation-suite/2023.10.5/hydrate-registry.sh
  • Linux:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.5/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.5/hydrate-registry.sh
2023.10.4
https://download.uipath.com/automation-suite/2023.10.4/hydrate-registry.sh
  • Linux:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.4/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.4/hydrate-registry.sh
2023.10.3
https://download.uipath.com/automation-suite/2023.10.3/hydrate-registry.sh
  • Linux:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.3/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.3/hydrate-registry.sh
2023.10.2
https://download.uipath.com/automation-suite/2023.10.2/hydrate-registry.sh
  • Linux:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.2/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.2/hydrate-registry.sh
2023.10.1
https://download.uipath.com/automation-suite/2023.10.1/hydrate-registry.sh
  • Linux:
    wget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.1/hydrate-registry.shwget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.1/hydrate-registry.sh
  • Windows:
2023.10.0
https://download.uipath.com/automation-suite/2023.10.0/hydrate-registry.sh
  • Linux:
    wget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.0/hydrate-registry.shwget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2023.10.0/hydrate-registry.sh
  • Windows:
as-images.txt
as-images.txt contains the name and version of the container images that must be pulled and uploaded into the external Docker registry.
2023.10.10
https://download.uipath.com/automation-suite/2023.10.10/air-images.txt
  • Linux:
    To download air-images.txt on a Linux machine, run the following command from the terminal:
    wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.10/air-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.10/air-images.txt
  • Windows:
    To download air-images.txt on a Windows machine, click here and rename the file to as-images.txt.
2023.10.9
https://download.uipath.com/automation-suite/2023.10.9/air-images.txt
  • Linux:
    wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.9/air-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.9/air-images.txt
  • Windows:
2023.10.8
https://download.uipath.com/automation-suite/2023.10.8/air-images.txt
  • Linux:
    wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.8/air-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.8/air-images.txt
  • Windows:
2023.10.7
https://download.uipath.com/automation-suite/2023.10.7/air-images.txt
  • Linux:
    wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.7/air-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.7/air-images.txt
  • Windows:
2023.10.6
https://download.uipath.com/automation-suite/2023.10.6/air-images.txt
  • Linux:
    wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.6/air-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.6/air-images.txt
  • Windows:
2023.10.5
https://download.uipath.com/automation-suite/2023.10.5/air-images.txt
  • Linux:
    wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.5/air-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.5/air-images.txt
  • Windows:
2023.10.4
https://download.uipath.com/automation-suite/2023.10.4/air-images.txt
  • Linux:
    wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.4/air-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.4/air-images.txt
  • Windows:
2023.10.3
https://download.uipath.com/automation-suite/2023.10.3/air-images.txt
  • Linux:
    wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.3/air-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.3/air-images.txt
  • Windows:
2023.10.2
https://download.uipath.com/automation-suite/2023.10.2/air-images.txt
  • Linux:
    wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.2/air-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.2/air-images.txt
  • Windows:
2023.10.1
https://download.uipath.com/automation-suite/2023.10.1/air-images.txt
  • Linux:
    wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.1/air-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.1/air-images.txt
  • Windows:
2023.10.0
https://download.uipath.com/automation-suite/2023.10.0/air-images.txt
  • Linux:
    wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.0/air-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2023.10.0/air-images.txt
  • Windows:
as-helm-charts.txt
as-helm-charts.txt contain the details for the UiPath® application helm chart that must be pulled and uploaded to an external Docker registry hosted on your environment.
2023.10.10
https://download.uipath.com/automation-suite/2023.10.10/embedded-helm-charts.txt
  • Linux:
    To download embedded-helm-charts.txt on a Linux machine, run the following command from the terminal:
    wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.10/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.10/embedded-helm-charts.txt
  • Windows:
    To download embedded-helm-charts.txt on a Windows machine, click here and rename the file to as-helm-charts.txt.
2023.10.9
https://download.uipath.com/automation-suite/2023.10.9/embedded-helm-charts.txt
  • Linux:
    wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.9/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.9/embedded-helm-charts.txt
  • Windows:
2023.10.8
https://download.uipath.com/automation-suite/2023.10.8/embedded-helm-charts.txt
  • Linux:
    wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.8/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.8/embedded-helm-charts.txt
  • Windows:
2023.10.7
https://download.uipath.com/automation-suite/2023.10.7/embedded-helm-charts.txt
  • Linux:
    wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.7/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.7/embedded-helm-charts.txt
  • Windows:
2023.10.6
https://download.uipath.com/automation-suite/2023.10.6/embedded-helm-charts.txt
  • Linux:
    wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.6/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.6/embedded-helm-charts.txt
  • Windows:
2023.10.5
https://download.uipath.com/automation-suite/2023.10.5/embedded-helm-charts.txt
  • Linux:
    wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.5/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.5/embedded-helm-charts.txt
  • Windows:
2023.10.4
https://download.uipath.com/automation-suite/2023.10.4/embedded-helm-charts.txt
  • Linux:
    wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.4/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.4/embedded-helm-charts.txt
  • Windows:
2023.10.3
https://download.uipath.com/automation-suite/2023.10.3/embedded-helm-charts.txt
  • Linux:
    wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.3/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.3/embedded-helm-charts.txt
  • Windows:
2023.10.2
https://download.uipath.com/automation-suite/2023.10.2/embedded-helm-charts.txt
  • Linux:
    wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.2/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.2/embedded-helm-charts.txt
  • Windows:
2023.10.1
https://download.uipath.com/automation-suite/2023.10.1/embedded-helm-charts.txt
  • Linux:
    wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.1/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.1/embedded-helm-charts.txt
  • Windows:
2023.10.0
https://download.uipath.com/automation-suite/2023.10.0/embedded-helm-charts.txt
  • Linux:
    wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.0/embedded-helm-charts.txtwget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2023.10.0/embedded-helm-charts.txt
  • Windows:
uipathtools
uipathtools is a CLI tool that contains a subset of uipathctl capabilities specific to health commands. The tool is backward compatible and works with any supported Automation Suite version. We recommend using uipathtools as the first step if you face any issue.
2023.10.10
To download uipathtools , run one of the following commands, depending on your OS:
  • Linux
    wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.10/uipathtools-2023.10.10-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.10/uipathtools-2023.10.10-linux-amd64.tar.gz
  • Windows
    wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.10/uipathtools-2023.10.10-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.10/uipathtools-2023.10.10-windows-amd64.tar.gz
  • MacOS
    wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.10/uipathtools-2023.10.10-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.10/uipathtools-2023.10.10-darwin-amd64.tar.gz
2023.10.9
  • Linux
    wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.9/uipathtools-2023.10.9-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.9/uipathtools-2023.10.9-linux-amd64.tar.gz
  • Windows
    wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.9/uipathtools-2023.10.9-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.9/uipathtools-2023.10.9-windows-amd64.tar.gz
  • MacOS
    wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.9/uipathtools-2023.10.9-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.9/uipathtools-2023.10.9-darwin-amd64.tar.gz
2023.10.8
  • Linux
    wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.8/uipathtools-2023.10.8-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.8/uipathtools-2023.10.8-linux-amd64.tar.gz
  • Windows
    wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.8/uipathtools-2023.10.8-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.8/uipathtools-2023.10.8-windows-amd64.tar.gz
  • MacOS
    wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.8/uipathtools-2023.10.8-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.8/uipathtools-2023.10.8-darwin-amd64.tar.gz
2023.10.7
  • Linux
    wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.7/uipathtools-2023.10.7-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.7/uipathtools-2023.10.7-linux-amd64.tar.gz
  • Windows
    wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.7/uipathtools-2023.10.7-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.7/uipathtools-2023.10.7-windows-amd64.tar.gz
  • MacOS
    wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.7/uipathtools-2023.10.7-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.7/uipathtools-2023.10.7-darwin-amd64.tar.gz
2023.10.6
  • Linux
    wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.6/uipathtools-2023.10.6-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.6/uipathtools-2023.10.6-linux-amd64.tar.gz
  • Windows
    wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.6/uipathtools-2023.10.6-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.6/uipathtools-2023.10.6-windows-amd64.tar.gz
  • MacOS
    wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.6/uipathtools-2023.10.6-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.6/uipathtools-2023.10.6-darwin-amd64.tar.gz
2023.10.5
  • Linux
    wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.5/uipathtools-2023.10.5-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.5/uipathtools-2023.10.5-linux-amd64.tar.gz
  • Windows
    wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.5/uipathtools-2023.10.5-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.5/uipathtools-2023.10.5-windows-amd64.tar.gz
  • MacOS
    wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.5/uipathtools-2023.10.5-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.5/uipathtools-2023.10.5-darwin-amd64.tar.gz
2023.10.4
  • Linux
    wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.4/uipathtools-2023.10.4-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.4/uipathtools-2023.10.4-linux-amd64.tar.gz
  • Windows
    wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.4/uipathtools-2023.10.4-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.4/uipathtools-2023.10.4-windows-amd64.tar.gz
  • MacOS
    wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.4/uipathtools-2023.10.4-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.4/uipathtools-2023.10.4-darwin-amd64.tar.gz
2023.10.3
  • Linux
    wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.3/uipathtools-2023.10.3-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.3/uipathtools-2023.10.3-linux-amd64.tar.gz
  • Windows
    wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.3/uipathtools-2023.10.3-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.3/uipathtools-2023.10.3-windows-amd64.tar.gz
  • MacOS
    wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.3/uipathtools-2023.10.3-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.3/uipathtools-2023.10.3-darwin-amd64.tar.gz
2023.10.2
  • Linux
    wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.2/uipathtools-2023.10.2-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.2/uipathtools-2023.10.2-linux-amd64.tar.gz
  • Windows
    wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.2/uipathtools-2023.10.2-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.2/uipathtools-2023.10.2-windows-amd64.tar.gz
  • MacOS
    wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.2/uipathtools-2023.10.2-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.2/uipathtools-2023.10.2-darwin-amd64.tar.gz
2023.10.1
  • Linux
    wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.1/uipathtools-2023.10.1-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.1/uipathtools-2023.10.1-linux-amd64.tar.gz
  • Windows
    wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.1/uipathtools-2023.10.1-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.1/uipathtools-2023.10.1-windows-amd64.tar.gz
  • MacOS
    wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.1/uipathtools-2023.10.1-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.1/uipathtools-2023.10.1-darwin-amd64.tar.gz
2023.10.0
  • Linux
    wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.0/uipathtools-2023.10.0-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.0/uipathtools-2023.10.0-linux-amd64.tar.gz
  • Windows
    wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.0/uipathtools-2023.10.0-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.0/uipathtools-2023.10.0-windows-amd64.tar.gz
  • MacOS
    wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.0/uipathtools-2023.10.0-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2023.10.0/uipathtools-2023.10.0-darwin-amd64.tar.gz
