Automation Suite API guide
- Getting started
- Authentication
- Scopes and permissions
- Platform Management APIs
- Get Settings
- Update Settings
Update Settings
As a host or organization administrator, use this endpoint to update existing settings or create new settings for a the specified organization and/or user ID.
API Endpoint
PUT /identity_/api/Setting
Scopes
Requires the following scopes:
- PM.Setting
- PM.Setting.Write
Request Headers
Note:
To obtain the {access_token}, make sure to authenticate through one of the methods described here.
Request Body
The request body contains the organization ID and the setting keys you want to update.
"settings": [
"key": "string",
"value": "string"
"partitionGlobalId": "string",
"userId": "string"
"settings": [
"key": "string",
"value": "string"
"userId": "string"
Responses
200 OK
The settings are updated with the information you provided.
Example Request
Let's say you gathered all the information needed to build the API call.
- Your
{baseURL}is:https://{yourDomain}/{organizationName}/{tenantName}/ - Your
{access_token}is:1234(for length considerations). - The
{partitionGlobalId}is:magic-7 - You want to update the authentication settings, so you log in as a host admin.
The call should resemble the following example (cURL):
curl --location --request PUT 'https://{yourDomain}/{organizationName}/{tenantName}/identity_/api/Setting' \)\)
--header 'Authorization: Bearer 1234' \)\)
--data-raw '
"settings": [
"key": "Auth.Password.DefaultExpirationDays",
"value": "0"
"key": "Auth.Password.PasswordComplexity",
"value": "{\"hasSpecialCharacter\":false,\"hasLowercase\":true,\"hasUppercase\":false,\"hasDigit\":true,\"Length\":\"10\"}"
"key": "Auth.Password.PreviousUseLimit",
"value": "1"
"key": "Auth.Password.ShouldChangePasswordAfterFirstLogin",
"value": "true"
"key": "Auth.UserLockOut.DefaultAccountLockoutSeconds",
"value": "0"
"key": "Auth.UserLockOut.IsEnabled",
"value": "false"
"key": "Auth.UserLockOut.MaxFailedAccessAttemptsBeforeLockout",
"value": "2"
"partitionGlobalId": "magic-7"
--data-raw '
"settings": [
"value": "0"
"value": "1"
"value": "true"
"value": "0"
"value": "false"
"value": "2"
Here is the response for a successful call:
"id": 4,
"value": "0",
"partitionGlobalId": "magic-7",
"userId": null
"id": 1,
"value": "{\"HasDigit\":true,\"HasLowercase\":true,\"HasSpecialCharacter\":false,\"HasUppercase\":false,\"Length\":10,\"RegexComplexity\":{\"HasDigitRegex\":\"(?=.*\\\\d)\",\"HasLowercaseRegex\":\"(?=.*[a-z])\",\"HasSpecialCharacterRegex\":\"(?=.*[^a-zA-Z\\\\d])\",\"HasUppercaseRegex\":\"(?=.*[A-Z])\",\"LengthRegex\":\"{10,}\",\"Regex\":\"(?=.*\\\\d)(?=.*[a-z]).{10,}\"}}",
"userId": null
"id": 3,
"value": "1",
"userId": null
"id": 2,
"value": "true",
"userId": null
"id": 26,
"value": "0",
"userId": null
"id": 27,
"value": "false",
"userId": null
"id": 28,
"value": "2",
"userId": null
"id": 4,
"value": "0",
"userId": null
"id": 1,
"userId": null
"id": 3,
"value": "1",
"userId": null
"id": 2,
"value": "true",
"userId": null
"id": 26,
"value": "0",
"userId": null
"id": 27,
"value": "false",
"userId": null
"id": 28,
"value": "2",
"userId": null
