- Getting started
- Host administration
- Organizations
- Authentication and security
- Licensing
- Accounts and roles
- External applications
- Notifications
- Logging
- Troubleshooting
Automation Suite admin guide
To access the UiPath platform, you only need an internet connection with TLS and a compatible web browser.
The following table lists the supported browsers.
Browser |
Version |
Google Chrome for Windows or MacOS |
2 latest versions |
Microsoft Edge Chromium for Windows or MacOS |
2 latest versions |
Mozilla Firefox for Windows or MacOS |
2 latest versions |
Apple Safari for MacOS |
latest version |
Unlisted browsers, older versions of the listed browsers, and mobile browsers are not supported. If you use any of these excluded types of browsers, certain features may not function as expected or errors may occur.
For information about the compatible versions of UiPath Robot and UiPath Studio, refer to the technical compatibility matrix.
