Last updated Dec 5, 2025
Installing Automation Suite
Installation overview
This page walks you through the high-level installation instructions for Automation Suite.
Before you begin, consider the following:
  • To deploy and manage Automation Suite, you must have knowledge of Kubernetes and cloud resource management. If you encounter issues installing and configuring Automation Suite, contact UiPath® Professional Services.
  • The installation process generates self-signed certificates on your behalf if you grant the installer admin privileges. You should replace them with certificates signed by a trusted Certificate Authority (CA) as soon as installation completes. For instructions, see Managing the certificates.
  • Automation Suite supports enabling Federal Information Processing Standard 140-2 (FIPS 140-2). For details, see Security and compliance.
Running the installation
To check which deployment scenarios are available for Automation Suite, refer to Deployment scenarios.
To install Automation Suite, take the following steps:
  1. After successfully validating the prerequisites, you install Automation Suite by running the following command:
    uipathctl manifest apply input.json --versions versions.jsonuipathctl manifest apply input.json --versions versions.json
    Note:
    If you encounter issues while running the installation, rerun the command the installation commands with all the arguments and flags.
  2. Validate that your installation is successful and services are healthy by running the following command:
    uipathctl health checkuipathctl health check
  • Installation overview
  • Running the installation
