- Getting started
- Authentication
- Scopes and permissions
- Platform Management APIs
Automation Suite API guide
Last updated Nov 11, 2025
Switch the secondary certificate to become the primary certificate.
POST https://{yourDomain}/{organizationName}/identity_/api/SamlCertificate/{partitionGlobalId}/switch
--header 'Content-Type: application/json'--header 'Authorization: Bearer {access_token}'\
--header 'Content-Type: application/json'Note: To obtain the
{access_token}, make sure to authenticate through one of the
methods described here.
200 Success
The secondary certificate has been successfully switched with the primary certificate.
"partitionGlobalId": "3fa85f64-5717-4562-b3fc-2c963f66afa6",
"primaryCertificateId": 0,
"primaryCertificate": "string",
"primaryCertificateThumbprint": "string",
"secondaryCertificateId": 0,
"secondaryCertificate": "string",
"secondaryCertificateThumbprint": "string"
