automation-ops
  • Release Notes
      • April 2025
  • Introduction
  • Governance
  • Logging
Automation Ops user guide for Automation Cloud Public Sector
Last updated Apr 11, 2025
Settings for AI Trust Layer Policies
The AI Trust Layer policy governs the use of third-party AI models managed by UiPath®, across products. The policy sets rules for your organization at tenant, group, or user level.
Product Toggles
Select the Feature Toggles tab to enable or disable the use third-party generative AI features at the product level.
Note:
There is a five-minute cache for the governance policies. This means that any modifications made to the policies, including all toggles, will only be in effect after the five-minute period.
For the AI Trust Layer policy, the following settings are available:
  • Enable calls to third-party AI models through AI Trust Layer - By default, this option is enabled. When disabled, it impacts all products that use third-party generative AI models.
  • Enable Autopilot for Everyone - By default, this option is set to Yes. When set to No, it prevents you from conversing with Autopilot for Everyone.
  • Enable Document Understanding features - By default, this option is set to Yes. When set to No, it disables any calls to third-party AI models, effectively turning off the functionalities related to generative annotation and automatic classification.
  • Enable Test Manager features - By default, this option is set to Yes, to leverage the AI-powered testing capabilities of Test Manager. When set to No, it disables the following:
    • the ability to automatically generate test cases from a requirement;
    • the ability to generate concise insights on the test execution results.
Note:
AI Trust Layer ensures that your data is never stored outside of UiPath®, nor is it used to train third-party models.
Feature Toggles
Select the Feature Toggles tab to control saving prompts for audit purposes. Admin users can decide if they want to populate the AI Trust Layer Audit tab with inputs and outputs or want to disable them. Once disabled, the inputs/outputs in the Audit details pane appear as Blocked by Policy.
The default setting for this feature has prompts saving automatically enabled. If you change the Enable input/output saving for Audit? setting to No, it turns off the function and prevents the saving of prompts. In this case, you cannot retrieve the prompts at a later point.
Models
Select the Models tab to manage the family models used by your products. It provides control over different AI models, namely the ability to enable or disable the following specific models:
  • Anthropic - disabled by default
  • Azure Open AI - enabled by default
When you enable or disable these models, it impacts the functionality of your products or services, as shown in the following table:
Product
Model Family
Context Grounding
Azure OpenAI
Autopilot for developers
Azure OpenAI
Test Manager
Azure OpenAI
Clipboard AI
Azure OpenAI, Anthropic
Apps
Azure OpenAI
Azure OpenAI
  • Overview
  • Product Toggles
  • Feature Toggles
  • Models
