2022.4
- Open API
- Introduction to Automation Hub API
 - API References
 - Generate your Token from Automation Hub
 - Input for Automation Pipeline
 - Input for Submission Type
 - Input for Phase
 - Input for Status
 - Input for Phase and Status Update
 - Input for Business Unit
 - Input for Applications
 - Input for Category
 - Input for Cost Benefit Analysis
 - Input for High Level Assessment
 - Input for Detailed Assessment
 - Input for Automation Idea Creation Date
 - Input for Users
 - Input for User Status
 - User Status Table
 - Input for Collaborators
- Output Dictionary
 - Automation Hub Open API Power Query Data Parsing
Automation Hub API Guide
Last updated Apr 19, 2024
The GET Collaborators call allows users to retrieve all the users assigned with a collaborator role within a specific automation idea.
Note:
         As an input parameter use the automation ID, in order to identify the Automation Idea for which you want to retrieve the list of collaborators.
                         Key  |
                         Value  |
                         Use Case  |
                         collaborators  |
                         Automation ID  |
                         GET request parameter  |
Example: collaborators=72 where 72 is the automation ID
UI Correspondent: Collaborators.
