test-suite
- Getting Started
- Studio
- Overview
- Testing Activities
- Configuring user machine
- Configuring SAP Solution Manager
- Configuring system under test
- SAP Solution Manager command line
- Use case scenarios
- Orchestrator
- Testing robots
- Test Manager
Test Suite User Guide
Last updated Jul 25, 2025
To prepare your system for automation ensure the following SAP Solution Manager Configuration steps:
- Completed Test Suite Preparation configuration
Completed Test Automation Preparation configuration
Note: SAP Solution Manager Configuration (SOLMAN_SETUP transaction) guides you through the configuration of SAP Solution Manager and assists you in connecting your managed systems to SAP Solution Manager. Its configuration scenarios provide a standard customizing for most of the important basic functions in SAP Solution Manager. You can discuss this with your SAP Administrator.
To configure SAP Solution Manager, follow these procedures:
For overall communication within the SAP Test Automation Framework, UiPath® requires a service user with the corresponding authorizations. For this purpose, you will be using ECATT_ET_USR.
- The user allows communication between SAP Solution Manager and UiPath®.
- The user allows communication between UiPath® and System Under Test (SUT).
The user allows internal communication between SAP Solution Manager and SUT (e.g. for TBOM recording).
Note: ECATT_ET_USR is automatically generated during the Test Automation Preparation procedure.
You can verify if the user exists in the transaction SU01 and check the corresponding authorisations in the Roles tab. No additional settings are required.
