task-mining
- Release notes
- Getting started
- Setup and configuration
- Working with Task Mining
- Additional resources
Uploading sata using continuous upload
OUT OF SUPPORT
Task Mining
Last updated Nov 11, 2024
When using the Continous settings, data upload occurs when needed, only if the user is online in the Task Mining desktop application. If you are using Network Shared Folder to store the data locally before data is uploaded, please refer to Using StudyUploader for uploading data.
- The My Progress from the desktop client settings shows the total data processed, amount uploaded, and pending upload.
If Task Mining isn’t able to upload a file, it retries a fixed number of times, following which it skips uploading that file. Finally, it retries uploading the skipped file after a cooldown period.
If the data upload fails, a notification informs the user, and the resume feature within the application can be used.
Upload status can be viewed on the Task Mining Team page for each user:
Note: The datasets you upload need to contain a minimum of 40,000 actions. Our recommendation is to upload data sets that contain
100K to 200K actions to get more optimal results.
