- Release Notes
 - Getting Started
 - Setup and Configuration
 - Automation Projects
 - Dependencies
 - Types of Workflows
 - File Comparison
 - Automation Best Practices
 - Source Control Integration
 - Debugging
 - The Diagnostic Tool
 - Workflow Analyzer
- About Workflow Analyzer
 - ST-DBP-023 - Empty Workflow
 - ST-USG-032 - Required Tags
 - Variables
 - Arguments
 - Imported Namespaces
 - Coded automations
 - Control Flow
 - Object Repository
 - Logging
 - Studio testing
 - Extensions
- About extensions
 - SetupExtensions tool
 - Screen resolution settings
- Group Policies
 - Multiple browser profiles
 - Group Policy conflict
 - Chrome Extension on Mac
- Group Policies
- List of extensions for Edge
 - SAP Solution Manager plugin
 - Excel Add-in
 - Troubleshooting
Studio User Guide
The integration between Studio and Automation Hub enables you to easily link Studio projects to ideas in Automation Hub:
- In Studio, you can link any project to an existing idea in Automation Hub by adding the idea URL in the project settings.
 - In Automation Hub, for any idea that is in the Development phase and has the Not Started status, you can select to start development in Studio, which automatically opens your Studio instance and creates a new project that is linked to the idea.
As a prerequisite, Studio must be connected through interactive sign-in to an Orchestrator tenant where the Automation Hub service is enabled. You can add Automation Hub URL links from any Automation Cloud tenant in your organization.
To link a Studio project to an idea in Automation Hub:
Managing the link to an Automation Hub idea
- To change the idea a project is linked to, repeat the steps in the linking procedure and replace the existing Automation Hub URL with the URL of a different idea.
 - To navigate to the idea a project is linked to in Automation Hub, in the Project Settings window, click the
 icon next to Automation Hub URL.
The option to start a Studio project from an idea in Automation Hub is available to users with the Start Development of projects assigned to CD Power Users permission, which can be assigned to any role in Automation Hub. After the permission is assigned, the user has the Start development in Studio option on ideas that are in the Development phase and have the Not Started status, regardless of their source or Development type. The status of the idea is changed from Development - Not started to Development - In Progress if the Start Development in Studio button is triggered.
To start a new Studio project from Automation Hub:
 > General.
