- Release notes
- Before you begin
- Getting started
- Integrations
- Managing access
- Working with process apps
- Creating apps
- Loading data
- Uploading data
- Setting up a SQL Server account for data upload using an extractor
- Loading data using Theobald Xtract Universal
- Customizing process apps
- Data transformations
- TemplateOne app template
- Purchase to Pay app template
- Order to Cash app template
- Basic troubleshooting guide
Process Mining
Last updated Apr 15, 2025
This page provides an overview the architecture of UiPath Process Mining - Automation Suite. UiPath Process Mining extracts data from source systems (for example, SAP, Salesforce, ServiceNow), transforms it into event logs, and displays it in interactive process dashboards.
Users access the Process Mining Portal to interact with dashboards that visualize their processes.
The Process Mining Engine is responsible for:
Data transformation: Moving the data from Blob storage to the data warehouse, and transforming the data for use in the dashboards.
Dashboard interaction: Calculating the process graph, charts and KPIs shown in dashboards.
Users can upload data files directly in portal or use Extraction tools to extract data from source systems and upload it to the data warehouse.
