document-understanding
2022.4
Document Understanding User Guide
Last updated Apr 4, 2025
Install and Use
This page describes how to deploy and configure Document Understanding, as well as special instructions on how to use Document Understanding on Automation Suite.
Dependencies
Document Understanding has a dependency on AI Center, meaning that AI Center always needs to be installed if Document Understanding is installed.
Also, Orchestrator must be activated before using Document Understanding.
Hardware Requirements
Before starting the Document Understanding installation, make sure to check and satisfy all requirements for Automation Suite for single-node here and for multi-node here.
A GPU is strongly recommended for Document Understanding in one of the following scenarios:
  • If you retrain the Document Understanding models (DocumentUnderstanding - the general model, Invoices, Receipts, etc.) on AI Center.
  • Training on CPU is 5-7 times slower and model performance degrades compared to training on GPU.
  • If you run UiPathDocumentOCR (non-edge version) on AI Center to process more than 2 million pages a year.
  • If you do not use a GPU, slow performance may impact the product experience.
  • For more details about how to provision a GPU, see Adding a dedicated agent node with GPU support.
SQL Server Requirements
Document Understanding requires the FullTextSearch feature to be enabled on the SQL server. Otherwise, the installation fails without an explicit error message.
Resources
Configuration file
  • Check the Document Understanding configuration file here.
Access to the models
  • Check this page for more information on how to access the models.
Enable or disable Document Understanding
  • As a post-installation operation, you can enable or disable Document Understanding. More details can be found here.
Troubleshooting
  • Check the Document Understanding-related issues here.
  • Dependencies
  • Hardware Requirements
  • SQL Server Requirements
  • Resources
  • Configuration file
  • Access to the models
  • Enable or disable Document Understanding
  • Troubleshooting
