- Getting started
- Authentication
- Scopes and permissions
- Platform Management APIs
- Get All Robot Accounts
- Delete Robot Accounts
- Get Specific Robot Account
- Delete Specific Robot Account
- Create a New Robot Account
- Update Robot Account
Automation Suite API guide
Last updated Feb 24, 2025
Deletes the specified robot account in an organization, based on the organization and robot account ID.
DELETE https://{yourDomain}/{organizationName}/identity_/api/RobotAccount/{partitionGlobalId}/{robotAccountId}--header 'Authorization: Bearer {access_token}'\
--header 'Content-Type: application/json'--header 'Authorization: Bearer {access_token}'\
--header 'Content-Type: application/json'Note: To obtain the
{access_token}, make sure to authenticate through one of the methods described here.
Path param |
Data type |
Description |
(required) |
String |
The ID of the organization you want to delete the robot accounts from. |
(required) |
String |
The ID of the robot account you want to delete. |
Let's say you gathered all the information needed to build the API call.
- Your
{baseURL}is:https://{yourDomain}/{organizationName}/{tenantName}/ -
Your
{access_token}is:1234(for length considerations). - The
{partitionGlobalId}is:magic-7 - The
{robotAccountId}is:33-ab
The call should resemble the following example (cURL):
curl --location --request DELETE 'https://{yourDomain}/{organizationName}/{tenantName}/identity_/api/RobotAccount/magic-7/33-ab' \
--header 'Content-Type: application/json'curl --location --request DELETE 'https://{yourDomain}/{organizationName}/{tenantName}/identity_/api/RobotAccount/magic-7/33-ab' \
