Automation Suite release notes
Release date: October 17, 2024
We have implemented a new kube-proxy check in the Node Monitor. If kube-proxy becomes functionally unavailable due to issues such as an iptable flush, the Node Monitor will cordon the node. Once kube-proxy functions correctly again, the node will be uncordoned.
We made the following improvements to the migration workflows:
When moving the Identity data of your tenants from standalone Orchestrator to Automation Suite, the tenant name in Automation Suite is now the same as the original tenant name in standalone Orchestrator. Previously, the Automation Suite tenant name was automatically generated in the
tenant_xxxxxxxxformat, wherexxxxxxxxsignified the first eight characters of the Automation Suite organization ID. For more information, see Step 1: Moving the Identity organization data from standalone to Automation Suite -
We updated our documentation of the migration steps to clarify that you have the option to migrate multiple standalone product tenants to either a single Automation Suite organization or multiple Automation Suite organizations. For more information, see Step 1: Moving the Identity organization data from standalone to Automation Suite and Step 4: Merging organizations in Automation Suite.
We have fixed an issue where shutting down the
rke2-serverservice without executingrke2-killall.shcould lead to intermittent not ready reports from agent machines. -
We have fixed an issue that caused problems during the upgrade process if you had resized the Docker-registry PVC used by your in-cluster Docker registry. Now, the new size is accurately recognized and considered during the upgrade process.
We have fixed an issue causing Redis recovery job failures when the ArgoCD admin password gets updated in the UI without also updating the Kubernetes secrets. The fix includes special handling for this scenario. We recommend to update the Kubernetes secrets at the same time when you update the ArgoCD admin password in the UI to avoid any other unexpected issues. For more details on how to properly update the ArgoCD admin password, refer to Troubleshooting.
Grafana dashboard error
Dashboard not found and
Invalid dashboard UID in the request appear in the Grafana
dashboard.
Modify the helm parameter for the
fabric-installerapplication. This automatically triggers the sync operation forfabric-installerapplication.kubectl patch application fabric-installer -n argocd --type='json' -p='[{"op": "add", "path": "/spec/source/helm/parameters/-", "value": {"name": "global.rancherMonitoring.grafana.replicas", "value": "1"}}]'kubectl patch application fabric-installer -n argocd --type='json' -p='[{"op": "add", "path": "/spec/source/helm/parameters/-", "value": {"name": "global.rancherMonitoring.grafana.replicas", "value": "1"}}]' - Sync the
rancher-monitoringapplication from ArgoCD UI.
We have fixed this issue in Automation Suite 2023.4.10.
Kube-proxy health check not working
node-monitor component, which monitors the node for issues such as checking kube-proxy health or if ip_forward is enabled, and cordons the node if issues arise, is not working for specific nodes such as GPU, task-mining, or as-robot. We have fixed this issue in Automation Suite 2023.4.12.
Email alerts configuration failure post upgrade
Erratum - added February 13, 2025: An issue affects the functionality of email alerts configuration and the setup of multiple receivers after upgrading from Automation Suite 2022.10. To address this issue, see Troubleshooting.
This issue is fixed in Automation Suite 2023.4.11.
Node maintenance issue in non-HA Redis
redis-cluster-0 pod to get stuck in the terminating state when you perform a node drain in non-HA Redis scenarios. To address the problem,
you must force delete the pod using the following command:
kubectl -n redis-system delete pod redis-cluster-0 --forcekubectl -n redis-system delete pod redis-cluster-0 --forceWe fixed the issue in Automation Suite 2023.4.10.
Insights annotation issue blocks installer
Erratum - added December 18, 2024: An Insights annotation issue blocks the Automation Suite installer. We fixed the issue in Automation Suite 2023.4.10.
RKE2 log collector runs indefinitely
Erratum - added December 18, 2024: The RKE2 log collector runs indefinitely for some system commands. We fixed the issue in Automation Suite 2023.4.10.
Pods cannot communicate with FQDN in a proxy environment
System.Net.Http.HttpRequestException: The proxy tunnel request to proxy 'http://<proxyFQDN>:8080/' failed with status code '404'.System.Net.Http.HttpRequestException: The proxy tunnel request to proxy 'http://<proxyFQDN>:8080/' failed with status code '404'.To fix the issue, see the Troubleshooting section.
OSD PV resize does not persist after upgrade
rook-ceph OSD PV, the new size does not persist
following an Automation Suite upgrade.
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Product versions
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
| DISCOVER | BUILD | MANAGE | ENGAGE |
Automation Ops 2023.4.8 | AI Center 2023.4.9 | Action Center 2023.4.9 | |
| Task Mining 2023.4.9 | AI Computer Vision 2023.4.9 | Insights 2023.4.9 | Apps 2023.4.9 |
| Document Understanding 2023.4.9 | Orchestrator 2023.4.10 | ||
| Test Manager 2023.4.8 | |||
Internal third-party component versions
This Automation Suite release bundles the following internal components:
Component |
Version |
RKE2 |
1.30.5 |
ArgoCD |
2.11.3 |
logging-operator |
4.6.0 |
| logging-operator-logging |
4.6.0 |
| gatekeeper |
3.16.0 |
rook-ceph |
1.14.6 |
| prometheus-pushgateway |
2.12.0 |
cert-manager |
1.14.5 |
rancher-istio |
104.4.0-up1.22.1 |
| rancher-logging |
103.0.0-up3.17.10 |
| rancher-logging-crd |
103.0.0-up3.17.10 |
| rancher-monitoring-crd |
104.1.0-up57.0.3 |
| rancher-gatekeeper-crd |
103.1.0-up3.13.0 |
| rancher-gatekeeper |
103.1.0-up3.13.0 |
| rancher-monitoring |
104.1.0-up57.0.3 |
longhorn |
1.6.2 |
longhorn-crd |
1.1.100 |
reloader |
1.0.95 |
csi-driver-smb |
1.16.0 |
velero |
6.2.0 |
redis-operator |
7.4.6-2 |
redis-cluster |
7.4.6-22 |
Migration tool version
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
- New RHEL version supported
- New kube-proxy check
- Improved migration to Automation Suite
- Bug fixes
- Known issues
- Grafana dashboard error
- Kube-proxy health check not working
- Email alerts configuration failure post upgrade
- Node maintenance issue in non-HA Redis
- Insights annotation issue blocks installer
- RKE2 log collector runs indefinitely
- OSD PV resize does not persist after upgrade
- Deprecation timeline
- Bundling details
- Product versions
- Internal third-party component versions
- Migration tool version
