Automation Suite admin guide
Last updated Aug 22, 2025
Managing organization settings
Organization settings are broadly-applicable and impact everyone who the UiPath platform. Settings can impact all tenants, all services, and all users, except where options exist to customize more granularly.
Accessing organization settings
If you are an organization administrator, you can access the Admin space, which includes the organization settings.
To access organization settings
  • From the App launcher (top left corner), select Admin. You are then redirected to the organization settings page.
  • If you are already browsing the Admin pages, select your organization name at the top of the panel on the left:
Changing the organization name or URL
  1. Go to Admin, select your organization, and then select Settings. The Settings page for the organization opens.
  2. In the Organization Name field, you can edit the name of your organization.
    You can enter up to 30 characters of any type, but the last character cannot be an underscore _.
  3. In the URL field, you can modify the URL for your organization.
    Rules:
    • up to 15 lowercase alphabetical or numeric characters
    • start with a letter
    • no spaces or special characters are allowed.
  4. When you're finished editing, select Save Changes to apply the new name or URL.
Changing the URL
Changing the URL for your Automation Suite organization (also known as your Account Logical Name) greatly impacts the entities that used the previous URL.
  • Robots configured at the services level are disconnected. If you change the URL, you need to reconnect your robots , entering the new URL.
  • Bookmarks containing the organization URL don't work anymore. You must send the new URL to your users.
  • Mobile Orchestrator users are disconnected. Send them the new URL to connect again.
After Changing Your Site URL
The URL is also known as your Account Logical Name or organization-specific URL. Changing the URL greatly impacts the entities that were using the previous URL:
  • Robots configured at the service level are disconnected. If you change the URL, you need to reconnect your robots, entering the new URL.
  • Bookmarks containing the organization URL don't work anymore. You must share the new URL with all your users.
Changing localization settings
You can change the language either globally, with the change being propagated to all the users accessing your organization, or at a local level, for yourself only. The default language is English.
Note:
In some cases, you might need to refresh the page or log out and then log back in so that all elements on the page are localized.
Global language settings
You can change the language used for system emails sent by Automation Suite and other services to your users.
If a service has a different language setting for system emails, that setting takes precedence.
User language settings
Each user can localize the user interface for themselves by selecting the desired language from the Preferences page. For details, refer to Selecting the user language.
For details about the supported languages across our products, refer to Localization Support .
Adding your company logo
You can display your own company logo in the header:
To add your logo
  2. Under Company Logo, select Upload light theme logo and select the logo image.
    You can upload an image file with a size of up to 3000 x 3000 pixels. We support formats that allow for transparent pixels, such as PNG. The image is automatically resized proportionally to a maximum width of 151 pixels.
  3. If your logo does not look good against a dark background, select Upload dark theme logo to also add an alternative image to use when users select the dark theme.
  4. Select Save to add your logo.
The appropriate logo for your current theme appears in the header.
Finding your support ID
Note:
The Support ID is only available if Automation Suite is licensed.
To view your support ID:
  • Go to Admin, select the organization in the left pane, and then Settings. The support ID is visible in the top right corner of the page. Select the copy icon to copy your support ID.
Changing the license management option
User license management allows you to get more out of user licenses because one license can be used across all tenants. When this setting is disabled, user licenses are bound to the tenant to which they are allocated.
For more information about this option, refer to User license management.
