- Getting started
- Host administration
- Organizations
- Authentication and security
- Licensing
- Accounts and roles
- About accounts and groups
- Managing Accounts and Groups
- Managing access
- External applications
- Notifications
- Logging
- Troubleshooting
Automation Suite admin guide
Organization administrators can view, add, edit, or remove accounts and groups for the Automation Suite organization from the Admin > Accounts and Groups page at the organization level.
You can add new groups if you want to define a custom mix of roles and license allocation rules to use for a particular group of accounts. For example, the ones needed by your colleagues in the Accounting department to use Automation Suite.
- In the Users and Groups page, navigate to the Groups tab.
- Click Add Group. The Add Group window is displayed.
- Fill in the Name field.
- On the Group Members field, add users to the group. Only users that have been invited to your organization beforehand are displayed here.
Unlike default user groups, custom groups need to be added manually to your services to allocate roles.
Adding User Accounts
The panel closes and the new account is available in the list of user accounts.
Adding Robot Accounts
The robot account is added and is now visible on the Robot accounts page. It is also added to the groups you selected.
Continue the setup of the robot account in UiPath Orchestrator as you would set up a user account for unattended use: Unattended Setup.
Adding an account - either user or robot - to a group means the account inherits the roles and licenses assigned to the group.
- Go to Admin > Accounts and Groups and select the Groups tab.
- At the right end of the group row, click
Edit. - In the Group Members field, type to search for a user or robot account.
- Select the account from the list of results to add it to the group.
- Click Save.
You edit accounts and groups in the same way:
- Go to Admin > Accounts and Groups and select the appropriate tab.
- At the right end of a row, click
Edit. - Make changes as needed.
- Click Save.
You can check the roles assigned to an account or group from UiPath Orchestrator.
Go to Tenant > Manage Access > Assign roles and click Check roles above the table. You can search for any account or group to see the assigned roles.
In the User Permissions window, each permission is listed on a per-folder basis. Adjacent to each permission, you can see whether it has been explicitly assigned or inherited from the tenant.
Removing an account or group from Automation Suite revokes the right to access Automation Suite - including all the UiPath services - and clears all role and license assignations.
- Go to Admin > Accounts and Groups, and select the appropriate tab.
- At the right end of the row, click
Remove. - Confirm the action in the confirmation dialog.
Effects of removal
For accounts: After the account is removed, the user or service can no longer log in to Automation Suite.
For groups, after the group is removed:
- Any roles, licenses, or robot setup for the removed group are revoked from all user accounts that belonged to the group.
- If a user account that was a part of the removed group does not have any other roles (either directly assigned or inherited from other groups), they can still log in, but they have read-only rights.
