Automation Suite admin guide
Last updated Nov 11, 2025
Unified Pricing: Licensing plan framework
Important:
The licensing information on this page applies to you if you are on Unified Pricing.
If you are on Flex, refer to Flex licensing plan framework.
You can use Automation Suite and Test Cloud with a licensing plan to match your automation needs and budget.
Plan overview
The following sections provide a high-level description of the licensing plans available in the Unified Pricing modelfor Automation Suite.
Standard
The Standard plan provides the following benefits:
  • It helps you discover opportunities for continuous process optimization.
  • It provides core governance, security, enterprise scale capabilities to enable IT to manage automation.
Enterprise
The Enterprise plan provides the following benefits:
  • It provides industry-leading governance, security, enterprise scale capabilities.
Plan breakdown
The following table describes the benefits of each licensing plan at platform level. For information on product-specific benefits, refer to each product guide.
Plan perksStandardEnterprise
Max. tenantsUnlimitedUnlimited
Data residencyCustomer choice, single region for orgs and tenantsCustomer choice per tenant
Access to UiPath SupportUiPath Bronze SupportUiPath Bronze Support
Standard auditYesYes
Advanced auditNoYes
Basic user managementYesYes
Check accessYesYes
Custom rolesYesYes
Single Sign-On and provisioningYesYes
Mail settingsYesYes
External credential storeNoYes
Customer Managed Keys (CMK)NoYes
Bring your own LLM subscriptionNoYes
Elastic Robot OrchestrationNoYes
Real-time monitoring and alerts in InsightsYesYes
USER LICENSES1
Basic UserAs purchasedAs purchased
Plus User
As purchased
As purchased
Pro UserAs purchasedAs purchased
ROBOT LICENSES
Automation Test RobotAs purchasedAs purchased
Unattended RobotAs purchasedAs purchased
CONSUMPTION UNITS
Platform UnitsAs purchasedAs purchased
Important: 1 In Unified Pricing, you must enable User License Management to view and manage user licenses.
  • Plan overview
  • Standard
  • Enterprise
  • Plan breakdown
