Automation Hub User Guide
Last updated Oct 13, 2025
My Components
Note: This option may not be displayed if the Company Admin decides to switch it off from the Settings page. For details please check the Updating the Settings page.
When accessing this page you have two lists containing the details for:
  1. components you uploaded (created);
  2. components you downloaded.
The components from each list are displayed in a tabular view that has the following options available:
  • Search for a particular component.
  • Sort the components you want to view by applying the available filters.
  • Show/Hide the columns from the list.
The Upload Component option allows you to add to the tenant components you created. These will be valuable assets during the idea review and implementation process. Please check the Uploading a Component page for the step by step process.
Note: The Upload Component option is also available when accessing the Explore > Explore Components module.
