- Release Notes
- Getting Started
- Permissions
- Starting as
- Admin Console
- Workspace
- Explore
- Share Idea or Automation
- Dashboards
- My Tasks
- Notifications
- Email Notifications
- Resources
- Process Mining Integration
- Studio Integration
- Task Capture Integration
- Automation Hub - Automation Cloud Integration
- Automation Store
- Additional Resources
Automation Hub User Guide
Provisioning From Automation Hub
linkTo complete the Phase 2 of the provisioning process, the Organization Administrator needs to access the Automation Hub service via any of the below methods:
a. Access Admin > Tenants > Automation Hub option displayed under the Services column b. Select the tenant that contains Automation Hub from the tenant switcher > click the Automation Hub icon in the left navigation bar.
As soon as the Automation Hub setup screen opens, follow the below steps:
1. Click Continue and based on specific cases, the following will happen:
2. Select the tenant from the following options:
Create a new Automation Hub instance
linkThis option creates a new Automation Hub instance on the selected tenant. You are assigned as the Account Owner for this new instance. If other Automation Cloud Organization Administrators exist, they are added to the Automation Hub instance automatically.
To access Automation Hub service from the Automation Cloud platform, the following steps are required:
• Organization Admin gives you access to the Automation Hub service in the tenant where Automation Hub is enabled.
• You need to accept the unique invite in order to access the Automation Cloud organization (click on unique URL from email invite).
• In order to access the Automation Cloud organization, you need to sign up by email or Azure AD identity).
• After connecting in Automation Cloud, you will be able to access the granted services.
3. After selecting the instance click Next step.
4. Select the migration type between the following options:
Full Migration
link- All users from your existing Automation Hub
instance are imported to Automation Cloud and receive e-mail invitations*.
Note: Only if the Azure Active Directory is not connected.
- All the invited users have to accept the e-mail invitation in order to access the Automation Hub service from Automation Cloud.
- The users are added to the Everyone group from Automation Cloud.
- You can modify the users afterwards from Automation Cloud.
- The users with the status Not Invited in Automation Hub are not imported to Automation Cloud.
- Your existing Automation Hub URL changes from
https://automation-hub.uipath.com/{tenantName}
to the new cloud URLhttps://cloud.uipath.com/account/tenant/automationhub_
. - All the old URLs from Automation Hub
are redirected to the new cloud URLshttps://cloud.uipath.com/account/tenant/automationhub_
Partial Migration
link- To validate and try out Automation Hub via Automation Cloud use your email address to access the Automation Hub tenant via
the
URL. - The other existing Automation Hub users are unaffected and can access the platform as they used to, through
. - All system emails and links will follow the
URL format. - To complete the migration process later access
the Full migration option from Automation Hub, available in Admin >
Account > Settings.
Note: If Azure AD is enabled in Automation Cloud, no email invite is triggered. You will connect with the Azure AD identity and the organization needs to prepare a communication plan to inform about the existence of the Automation Cloud organization.
After selecting the migration option, click Confirm.
