automation-cloud-public-sector
Automation Cloud Public Sector admin guide
Last updated Sep 25, 2025
About Automation Cloud Public Sector
Automation Cloud Public Sector is a cloud-based enterprise SaaS solution tailored to the specific requirements of public sector organizations in the United States. Our platform helps you manage all your automation work and resources in one place. It is designed to provide you with a frictionless startup experience, streamlined collaboration, effortless scalability, and instant access to new functionalities.
Public sector organizations have specific requirements that demand robust, secure, and compliant software solutions. These organizations handle vast amounts of sensitive data, from citizen records to financial transactions, making data security and privacy paramount.
UiPath Automation Cloud Public Sector holds FedRAMP Moderate compliance, confirming our adherence to the rigorous security controls mandated by the Federal Risk and Authorization Management Program.
Key benefits
  • Data encryption: To achieve FedRAMP compliance, we employ FIPS 140-2 validated encryption for data at rest and in transit, ensuring the highest level of data protection.
  • TLS protocol: Our software utilizes TLS 1.2 or higher to secure data transmissions, guaranteeing the confidentiality of your information during transit.
  • Integration assurance: Any third-party services integrated with our platform maintain an equivalent FedRAMP certification.
  • Access control: UiPath backend access is restricted to US permanent residents and citizens located within US soil, reinforcing data security.
  • Secure images: Our services utilize secure images for all components to eliminate vulnerabilities and bolster security.
Product and service offering
The UiPath platform consists of various products designed to automate processes, enhance collaboration, and drive operational efficiency:
  • Action Center
    UiPath Action Center is a tool designed to help you manage and resolve exceptions, errors, or decisions that require human intervention in your automation workflows. It provides a central interface for handling these exceptions, allowing human workers to review, make decisions, and take actions as needed to ensure the successful completion of automated processes.
  • AI Computer Vision
    UiPath AI Computer Vision is a machine-learning based method used to visually identify all the UI elements on a computer screen and interact with them via UiPath Robots, simulating human interaction. It does not require or use the underlying properties of applications, but only the aspect and relationship of various screen elements.
  • Apps
    UiPath Apps is a low-code application development platform that enables you to build and share enterprise-grade custom applications that deliver engaging user experiences. Using Apps, you can quickly build custom business applications that connect to data in any underlying cloud or on-premises system using the power of automation.
  • Automation Cloud Robots - VM
    UiPath Automation Cloud Robots - VM is a hassle-free solution that streamlines the process of setting up the necessary infrastructure for running automations. It provides ready-to-use virtual machines where you can run automations. You just need to configure the virtual machine based on your need, and it is all set to run your tasks.
  • Automation Hub
    UiPath Automation Hub is a collaborative process identification, automation pipeline management, and process repository tool. Its goal is to accelerate the adoption of RPA across your organization, by building an RPA Community of Interest.
  • Automation Ops
    UiPath Automation Ops is a tool that enables you to manage and implement governance policies based on user profiles, and to manage the feeds available in your organization.
  • Data Service
    UiPath Data Service is a persistent data storage service that brings no-code data modeling and storage capabilities to your automation projects.
  • Document Understanding
    UiPath Document Understanding uses pre-defined solutions to extract and categorize data from common document types. Utilizing pre-trained models, it can pull information from standard documents with ease.
  • Insights
    UiPath Insights is a tool that serves as a platform for data modeling and analytics using a combination of available business metrics and operational insights into your automations and robot performance.
  • Integration Service
    UiPath Integration Service is the component of the UiPath Platform that makes the automation of third-party applications much easier by standardizing authorization and authentication, helping you manage API connections, and also allowing faster integration into SaaS platforms. By using prebuilt APIs, the development of automation projects in UiPath Studio is more simple and more consistent, regardless of the third-party applications you are automating.
  • Orchestrator
    UiPath Orchestrator is a tool for streamlining the deployment, monitoring, and governance of your automation processes and robots, giving you flexibility to schedule and trigger these processes as per your requirements. It also supports the management of transactional data, often used in automating business processes.
  • Process Mining
    UiPath Process Mining is a process mining solution that transforms data from your IT systems into visual interactive dashboards, allowing you to view existing value decreases, bottlenecks, and discrepancies, as well as understanding the root-causes and possible risks. It offers real-time, valuable insights to improve business processes over time.
  • Task Mining
    UiPath Task Mining offers insights into ongoing processes on your team's desktops, uncovering potential areas for automation and process improvement. This tool logs desktop data for each user action and uses AI to analyze it, thereby, giving you actionable insights for identifying automation ideas.
  • Test Manager
    UiPath Test Manager is a test management tool for enterprise testing. It integrates into your ecosystem and adapts to your way of working, whether you use ServiceNow, SAP Solution Manager, Jira, Azure DevOps.
We are currently in the process of onboarding several other products. Stay tuned.
  • Key benefits
  • Product and service offering
