- Getting Started
 - Network requirements
 - Single-node requirements and installation
 - Multi-node requirements and installation
- Accessing AI Center
 - Provision an AI Center tenant
 - Updating Orchestrator and Identity Server certificates
 - Resizing PVC
 - Adding a new node to the cluster
 - ML packages offline installation
 - Configuring the Cluster
 - Configuring the FQDN post-installation
 - Backing up and Restoring the Cluster
 - Using the Monitoring Stack
 - Setting up a Kerberos Authentication
 - Provisioning a GPU
 - Using the configuration file
 - Node scheduling
 - Migration and Upgrade
 - Basic Troubleshooting Guide
AI Center Installation Guide
| What you need | Requirements | Configuration | Installation |
                               One Linux machine (RHEL 8.2, 8.3, 8.4, 8.5)  | Multi-node machine requirements | Configuring the machines | |
                               SQL Server (MS SQL 2016, 2017, 2019 - Enterprise and Standard)  | - | Configuring MS SQL Server | - |
| DNS | - | Configuring the DNS | - |
| Load balancer | - | Configuring the load balancer | - |
This is the only configuration supported for production deployments.
                               Bundle  |
                               Minimum  |
                               Recommended  |
                               Node count  |
                               At least 3 server nodes. There must be an odd number of server nodes in a cluster to have increased fault tolerance Any number of agent nodes.  |
                               (v-)CPU total  |
                               48 (v-)CPU  |
                               64 (v-)CPU  |
                               Minimum (v-)CPU per node  |
                               12 (v-)CPU  |
                               16 (v-)CPU  |
                               RAM total  |
                               96 GiB  |
                               144 GiB  |
                               Cluster disk for each node  |
                               256 GiB SSD Min IOPS: 1100  |
                               Data disk for each server node  |
                               2 TiB SSD Min IOPS 1100  |
                               etcd disk for each server node  |
                               16 GiB SSD Min IOPS: 240  |
                               UiPath Bundle Disk (For offline installation only, on the first server node)  |
                               512 GiB SSD Min IOPS: 1100  |
Additional agent node with GPU support for Document Understanding
                                  Bundle  |
                                  Requirement  |
                                  (v-)CPU  |
                                  8 (v-)CPU  |
                                  RAM  |
                                  52 GiB  |
                                  Cluster disk  |
                                  Data disk  |
                                  N/A  |
                                  GPU RAM  |
                                  11 GiB  |
Advanced storage and compute requirements
                                  Use  |
                                  CPU  |
                                  RAM (GiB)  |
                                  GPU  |
                                  Hardware usage right after install  |
                                  30 (for minimum configuration) 33 (for recommended configuration)  |
                                  48  |
                                  0  |
                                  Minimum for serving (ML Skill, one replica)  |
                                  0.6  |
                                  2  |
                                  0  |
                                  Minimum for Training (Pipeline)  |
                                  1  |
                                  4  |
                                  0  |
                                  Document Understanding model Serving (ML Skill, one replica)  |
                                  1  |
                                  4  |
                                  0  |
                                  Document Understanding model Training  |
                                  2  |
                                  24  |
                                  1  |
