test-suite
Test Suite User Guide
Last updated Apr 28, 2025
Direct connection to SAP instance
To create an integration between your Test Manager project and your SAP system to collect data periodically, using a connection to your SAP system:
  1. Open your project in Test Manager, and go to Project Settings > Integration.
  2. Select SAP from the New Connection dropdown.
    The Edit connection dialog pops up.
  3. Fill in the fields according to the data from your SAP system:
    1. Name - name the integration between Test Manager and SAP.
    2. Description - describe the integration between Test Manager and SAP.
  4. Select ConnectSapInstance from Data Source:
    1. Application Server—IP address that your SAP system is working on.
    2. System name—three-letter SAP system ID.
    3. Instance Number—SAP system number.
    4. Client—SAP client to log into.
    5. User—SAP user name.
    6. Password—SAP password.
    7. Polling Interval—time interval when data is brought from the SAP system. The minimum value for this is one hour.
  5. After you finish the configuration of the integration, select Save.
  6. Refresh your project. The Heatmap page appears in the left-hand menu of your Test Manager project.
Integrating SAP NetWeaver RFC SDK - Automation Suite
This task demonstrates how to integrate the SAP NetWeaver RFC SDK with your SAP system, so you can use the heatmap in Test Manager deployed with Automation Suite.
  1. Download the SAP Netweaver RFC SDK 7.50 and extract it.
  2. Navigate to the lib folder and save this folder path.
    In the lib folder you'll find the libraries as .so files.
  3. Copy the libraries to your Automation Suite storage, using the Test Manager migrator shell script.
    • For External object storages - run the following command in Powershell:
      ./testmanager_migrator.sh -sap <storage_folder_location> -y./testmanager_migrator.sh -sap <storage_folder_location> -y
    • For InCluster Ceph Object storages - run the following command in Powershell:
      ./testmanager_migrator.sh -sap <storage_folder_location> -is -y./testmanager_migrator.sh -sap <storage_folder_location> -is -y
    Replace storage_folder_location with the path you saved at Step 2.
After you move the SAP libraries to your Automation Suite storage locations, perform the following validation steps:
  1. Check if you can access Test Manager inside Automation Suite.
  2. You can create a custom connection with your SAP system in a Test Manager project.
  • Integrating SAP NetWeaver RFC SDK - Automation Suite
