test-suite
2022.4
- Getting Started
- Studio
- Orchestrator
- Testing robots
- Test Manager
Troubleshooting Scenarios
Test Suite User Guide
Last updated May 14, 2025
If you run into issues, consider the following troubleshooting scenarios:
If your iOS device fails to start, try the following:
- Make sure that your device is trusting the certificate. On your device, go to Settings > General > Profiles & Device Management, tap on the email entry (e.g. Apple Development: [email protected]), and then trust the certificate. If the device is using your corporate account, this would not be needed.
- If you get an error that port 8100 is not accessible, close Appium (Control + C) and then restart it.
- If you get a different error, consider looking through Appium XCUITest Driver Real Device.
