- Getting started
- Administration
- Designing automations
- Creating an automation from an idea
- Creating a project
- How to start an automation
- Managing project files and folders
- Connecting automations to your accounts
- Configuring activities
- Managing the activities in a project
- Passing values between activities
- Iterating through items
- Managing the data in a project
- Configuring a project to use your data
- Using file and folder resources
- Using UI Automation for browser interactions
- Running and testing your projects
- Managing automations
Studio Web for Automation Suite User Guide
linkAn essential part of any automation is moving data from one step in the workflow to
another. Variables save the output of one activity and enable you to then use that data
as input in other activities later in a project. To make it easier to work with
variables, Studio Web automatically generates a variable for every activity output. You
can also manually create variables from the Data Manager or from the
See more
menu of activity
fields. Please note that automatically generated variables for activities placed inside
a scope activity are only available inside that scope activity.
Each activity output generates a variable of a specific data type that can contain various properties of the output data. When you then use it in another activity, you select the variable for the property depending on the data you need and the type supported by that activity.
- Variables that are automatically generated by Studio Web for activity outputs are displayed under the activity where they were generated.
- You can navigate to the variable property you want to use, or use the search bar to find it. For some variables, the most common properties appear at the top of the list, and you can view all available properties by clicking Show more.
- Because variable properties and activity fields can have different data types, not all variables can be used in all fields.
- An icon next to each variable indicates the type, for example Tt for text, 123 for number, 1.2 for number with decimal.
If you add a Write Cell activity to write the email address of the sender in a spreadsheet, you select the From address property variable to indicate what to write in the spreadsheet.
