document-understanding
Document Understanding User Guide
Last updated Sep 15, 2025
Use Document Manager
This page describes how to use Document Manager to label a new dataset and retrain an ML model.
Access and configure Document Manager
Launch the created data labeling session in First Run Experience and go to the settings to configure the OCR.
Choose the OCR you intend to use in the OCR method dropdown menu. For UiPathDocumentOCR, paste the Document UnderstandingTM license key (retrieve the Document Understanding API key from the Admin > License page) and then paste the OCR URL you generated when you deployed UiPathDocumentOCR.
Configure the prelabelling with the models that you have deployed following the instructions here. Paste the model public ML Skill endpoint and the Document Understanding license key, and then select Save.
For more details, please check the documentation here: Use a predefined schema.
Import document
  1. Select the Import button docs image from a Document Manager Session.
  2. Name the dataset and select Browse files to upload.
  3. Select the document you want to upload.
  4. Select YES.
Create extraction fields
Select Plus icon to create fields to be extracted.
You can create up to 40 fields.
For this validation exercise, you can create some common invoice fields such as date, name, invoice-no, and total. Please ensure to change the content type accordingly - date (date), name (string), invoice-no (string), and total (number).
Label documents
Now you can start to label the documents.
Select the Predict button Predict icon on top to use the base invoice model to predict the labels for the defined fields, and correct it if the prediction is wrong.
To change the label, drag the mouse over the field and hit the keyboard shortcut to label it.
Use the arrow on top to switch to the next document until you have finished the validation of labels for all uploaded invoices.
Note: Since the Invoices base model has already performed really well and the sample invoice is simple without too much variation, the prediction accuracy is close to 100% in this case and you may not need to correct any labels.
Export documents
  1. Make sure to select the correct dataset in the dataset filtering and select the Export button Export icon.
  2. Select Export.
  3. Go to Datasets under the same AI Center project, you should observe the exported training dataset.
Train a custom model on AI Center
  1. Go to Pipelines > Create new. Please select the evaluation run type, select the model package and the input dataset.
  2. Select the sub folder under Export as the input dataset.
  3. Select Create to start the pipeline. It may take 1-2 hours for the pipeline to run on CPU machines.
Deploy the retrained ML model as an ML Skill
Go to ML Skills and create a new ML Skill.
Choose the same invoice model package created before. As we have retrained the model, now there is a new minor package version (1 vs 0). Please make sure to select the latest.
Once the ML Skill is created, please go to Modify current deployment to make the ML skill public. Switch the toggle and select Confirm.
Copy the URL of the public ML Skill for later use.
Congrats! You have now retrained an Invoice model with your own dataset and created the endpoint to access the model.
