document-understanding
Document Understanding User Guide
Last updated Mar 5, 2025
Use the Framework
As a Studio workflow, you could use the .
Use Form Extractor, Intelligent Form Extractor, and Intelligent Keyword Classifier
Double click the workflow in the framework, and replace the endpoint per instruction here and add the Document UnderstandingTM license key.
  • Endpoint: the public URL from Access to the models
  • ApiKey: copy it from Automation Suite (Admin > Licenses > Robot & Services > Document Understanding)
Run the workflow. The robot will process the documents one by one. When the Validation Station pops up, click OK to test if the workflow is running properly.
Use custom Machine Learning Extractor
Double click the workflow in the framework and replace the endpoint with the public ML Skill endpoint from the deployed ML package following the instruction here and add the Document Understanding license key.
  • Endpoint: the public ML Skill endpoint from Deploy an out-of-the-box ML Package
